![]() | Home > In Car Electronics > Reverse Camera Lines - Predictive? |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Had a feeling you only had the "bendy Lines" lines on a RRS1 if you have the surround camera system fitted, could be wrong though.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Thanks Col
No you have certainly seen them as I have them, but I do have surround cameras and dual view but don't think that has anything to do with them.
Russben Member Since: 27 Mar 2013 Location: Lancashire Posts: 278 ![]() ![]() ![]() |
Did I read somewhere on here that you can enable the 'bendy' lines by putting it into reverse then pressing the screen to change between static & dynamic lines?
This is purely a guess and the "bendy lines" are part of the Surround Camera option which also includes the Tow Assist Facility, now even if you don't have the surround cameras it might be possible to activate Tow Assist in the CCF Files and it give you "bendy lines" I don't know it is only a thought.
I have straight and dashed lines or either side of screen view, but think that's just standard view? |
John, when you activated Tow Assist in the Configuration files did it do anything like give a fault or message saying anything about this option not being fitted or something to that effect or was the option not even listed in the files.
Hi Col, It was listed in config files, but on trying to turn on, it did "inform" me that the function isn't fitted, and so nothing was switched on. Was going to give GAP a call next week to check if I'm doing it correctly and if anyway to switch options on that aren't fitted basically. I have a FBH fitted, but although it allows me to set up for timer etc, nothing is shown or happens which is also strange. But when my timer unit is fitted I will see where I went wrong in turning on.
Hi John,
tonywolf Member Since: 14 Sep 2015 Location: Devon Posts: 97 ![]() ![]() ![]() |
Morning all, Bodsey may well know if it's possible to enable or retrofit Tow Assist👍 Best Regards
