Home > Faults & Fixes > Remotes won't open Range Rover sport 4.2 supercharged
Supercharged lad
United Kingdom 2005 Range Rover Sport Supercharged Autobiography Java Black
Hi there
Turned the car around before all normal just been out to it an neither of my remotes will unlock it the red alarm is flashing in the dash any ideas ???
Post #502366 Sun Aug 07 2016 9:19pm
Paddi
You have probably found out by now that there is a keyhole in the passenger side front door handle under the plastic cap for just this situation.
Best likely situation - possibly just a flat battery in the remote that you usually use and the spare (if you haven't used it for a while) may also have a flat battery. The batteries can be replaced but it can be a struggle to break open the remote to do it. Plenty of guides on here and the Disco3 site. 2008 MY Java Black TDV8 HSE
Post #502451 Tue Aug 09 2016 4:08pm
Supercharged lad
Thanks for the reply paddy
I tried going for a long run with my usual key in the car but was the same so tonight I have run the car with my spare key in for a good hour but still nothing Big Cry so will now look into changing batteries in the remotes thanks very much for getting in touch I will let you no how I get on
Post #502454 Tue Aug 09 2016 5:28pm
Paddi
Breaking open the fob to change the battery is a bit of a task so might just be worth popping in to a local garage and asking them to test the fob with a RF detector to see if it is transmitting anything. Most decent garages have these.
If you do have to open the fob then take care not to stab yourself in the process!
Some have resorted to using an oyster shucking glove for protection Rolling with laughter 2008 MY Java Black TDV8 HSE
Post #502455 Tue Aug 09 2016 5:55pm
