Home > Technical > P0730 p0735 transmission problem help please
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
morning friends
I got a issue with my 2008 2.7 tdv6 rr sport gearbox
I've just rebuilt the whole engine which is another story. Anyway I've dropped the engine in pit the body down and turned the key.
All is well with the engine but I could hear a noise from the gearbox.
Took it for a slow drive around my garage complex and everything was fine. Took it back out around the complex for the 3rd time and it was like the clutches were slipping. More revs to move ect. Drove it 20 steps back to the garage and heard a bang and that's where I am now.
Lost all drive in every gear. As soon as you select a gear it comes up with the faults listed above.
I have read about the codes and most turn out to be gearbox rebuild but I'm not so sure with only 20k on it. Plus was perfect before engine out.
I will rebuild the transmission myself if it's broken but would like some info on if there is anything to check before taking it out or apart..... Yes I'm more than competent.
Any help for a suffering rr owner would be brilliant
Thanks in advance
Jon
Post #502290 Sat Aug 06 2016 9:46am
The codes refer to the slip between input and output shaft speeds being too high. 0730 is incorrect gear ratio, 0735 is fifth gear incorrect gear ratio. The speed sensors are part of the mechatronic unit and aren't serviceable items apparently. Perhaps, as you say, it needs a rebuild of the box itself but it's odd that it's suddenly gone when you've put it back together. First thought is: did you put it back together correctly? Not meant to be a "go" at you, but if the only thing you've done to it is take it out and put it back then it's the first thing to check.
These might be of interest (although a tad old):
http://overcoiled.com/cars/Aston/ZF%20Repair%20Manual.pdf
http://www.rangerovers.net/forum/6-range-r...rdown.html 2012 SDV6 - it's missing a couple of cylinders
Post #502298 Sat Aug 06 2016 1:01pm
