Home > Technical > P0730 p0735 transmission problem help please |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8987 |
The codes refer to the slip between input and output shaft speeds being too high. 0730 is incorrect gear ratio, 0735 is fifth gear incorrect gear ratio. The speed sensors are part of the mechatronic unit and aren't serviceable items apparently. Perhaps, as you say, it needs a rebuild of the box itself but it's odd that it's suddenly gone when you've put it back together. First thought is: did you put it back together correctly? Not meant to be a "go" at you, but if the only thing you've done to it is take it out and put it back then it's the first thing to check.
Sat Aug 06 2016 1:01pm |
