![]() | Home > General > TDV8 tank range |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
I don't run it right down, but about 320-350 I think. I get approx 20mpg only as many small trips with a small amount of longer journeys 2010 TDV8 |
Eaters Member Since: 11 Apr 2016 Location: East Sussex Posts: 1543 ![]() ![]() ![]() |
Search TDV8 mpg for more posts in this forum Robin
jamesbilluk Member Since: 28 Jun 2016 Location: Worcester Posts: 23 ![]() |
Many thanks, about what I was getting from my disco 4 which is good! |
In days gone by, the fuel tank always use to give you around a guaranteed 325 miles regardless of car, or way you drive, some having twin tanks to reach that.
Mail Order Ride Member Since: 28 Feb 2009 Location: UK Posts: 131 ![]() |
It obviously depends on what kind of driving you are doing
Many thanks guys,
My current trip from Sussex to Aberdeen and back is halfway through and I'm averaging 27.1 mpg (actual) on 1041 miles. Around the speed limit on motorways and touring speed on Aberdeen's A roads. Biggest difference to mpg IMHO is to anticipate the road ahead. More e.g. overrun up to roundabouts etc. without using the brakes - and it's more comfortable for your passengers. This then leaves more opportunity for a blast or two when the mood takes you or when that caravan is too slow. |
27 is great, certainly would be very happy with that!
Hi Guys,
James, You may well be aware, but just in case. Never run your fuel down that low, if the readout is wrong, or you do more miles looking for an open filling station you could run out of fuel, and that can be very expensive repair required, including Cats. |
Certainly don't want to leave it that low again |
