![]() | Home > Technical > Steering wheel offset |
ilard Member Since: 20 Aug 2010 Location: London Posts: 975 ![]() ![]() |
RR London are going to take a look on Friday and are confident they can sort it out.
Meiang Member Since: 29 Apr 2011 Location: Perth Posts: 403 ![]() ![]() ![]() |
I am extremely fussy about my steering wheel being straight (and I mean straight) when driving on road with normal camber. I find that it takes 3 to 4 goes by a tyre shop to get it right when they have done a wheel alignment hence if my car drives straight I don't get the wheels aligned - why would you and cause yourself a whole load of grief. A static wheel alignment in the shop with the wheel straight will not result in a driving situation on normal camber with the wheel straight.
Good luck. It seems almost no-one can ever carry out a 4 wheel alignment properly. 2008 MY Java Black TDV8 HSE ![]() |
Well... It's now 95% right.
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
Is your calibration correct? |
With everything correct except the steering wheel on a BMW, I just moved the wheel so it was now dead central on spine, not offset 5 degrees, re lock, no further problems. Don't know if you can adjust just the steering wheel like that on the RRS but you can on most. John
