Home > Wheels & Tyres > Does Offset Matter ?
IRBails
Australia
I am after some 20 inch Rims and the choice here in Australia for OME 20's is pretty good. Most of the 20 inch Rims on Flee Bay are older models with 53 mm Off Set. I notice that My 2016 RRS has 49 mm offset and am wondering if the 4 mm difference will cause an issue? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #495092 Tue May 03 2016 9:50pm
TheWojtek
Not really. Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #495093 Tue May 03 2016 10:44pm
SPX
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
-4mm definitely not, +4mm sometimes can though if the brakes are very close to the wheel spokes.
Post #495096 Tue May 03 2016 11:43pm
IRBails
Australia
I have purchased some 20 inch wheels to replace the useless 22 inch wheels which are just for show. I hope the 4 mm does not matter as I did not try the wheels on, they are the Genuine older model wheels . I did check the inside for load rating though. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #495297 Fri May 06 2016 9:09pm
IRBails
Australia
Well I can tell you a slight difference in off Set does matter. The Front suspension will rub the tyre with 5 mm difference in offset. So be very care full. I have just fitted some OME RRS wheels with 53 off set and there is .5 of a mil between tyre and the suspension up right component on the front. My situation made a little worse by running 285/50 R20 Coopers. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #501021 Sun Jul 17 2016 1:41am
Tyrefitter
I've just fitted my 22's with 50 off set & 295/40r22's & their is about 5mm between tyre & strut.
Andy Andy.
21 Ford Ranger
Gone but not forgotten
Focus RS Red Edition
2015 RRS AB Fuji.
2014 RRS SC Santorini
2016 VW Amarok
2014 RRS AB Fuji
2012 RRS Red Edition Fuji
2015 Nissan Navara
2012 RRS SE Santorini
2008 RRS White
2007 RRS Santorino
Post #501031 Sun Jul 17 2016 8:19am
Olly-ibiza
Just put a 5mm spacer on spiteful Range Rover Sport tdv8
Post #501034 Sun Jul 17 2016 8:28am
IRBails
Australia
Can I ask where one would get a spacer from ? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #501049 Sun Jul 17 2016 11:22am
Olly-ibiza
Type 5mm wheel spacer in to ebay, there's gazillions of them spiteful Range Rover Sport tdv8
Post #501051 Sun Jul 17 2016 12:46pm
IRBails
Australia
Anyone have the PCD to mind to save me finding it for the RRS? Did find 6mm spacers listed but am concerned if this will impact the amount of thread available for contact with the studs? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #501081 Sun Jul 17 2016 9:59pm
German-wheels
RRS has PCD of 5x120, center bore of 72.6.
If I were you I would try the wheels on the car to see how they sit before fitting spacers, if the spacers are not hubcentric you could get some wheel wobble etc.
I wouldn't see 5mm being an issue, try and turn your wheels full lock one way and have a look at the back of the wheel and it's clearance to the strut, also make sure there is some clearance to the calipers.
May be worth posting the width of the wheels you currently have and the new ones. Will be a number like 9.5j
Post #501779 Wed Jul 27 2016 7:26pm
IRBails
Australia
Thks for that I found the PCD , Looking at making some steel shims about 2mm , the tire rub is very light and I could probably leave as is but the low speed squeak makes the car sound cheap. M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #501785 Wed Jul 27 2016 9:45pm
J2D
I am looking to purchase some 22" x 10 Riviera wheels for my 2011 plate RRS, the offset is et30, I'm sure these will fit, but worried they will stick out too far!?
Anyone else fitted 22" wheels to theirs with a 30mm offset?
Thanks
John
Post #502611 Thu Aug 11 2016 6:19pm
IRBails
Australia
The way I understand off set your wheel would be moved out about 19 mm with a 30 off set? M16 SVD8 ,4.4 HSE with a few extras, Sold R50 , Wife SQ5 , BMW R1200GSW.
Post #502659 Fri Aug 12 2016 11:15am
Thehos
Same pcd and centre bore as bmw
Post #502684 Fri Aug 12 2016 6:54pm
