![]() | Home > General > Factory Autobiography Kit? |
Surely from new you would order the Autobiography, not the HSE, as the cost difference to upgrade I would think would be more expensive.
insiorc Member Since: 17 Jul 2016 Location: Scotland Posts: 533 ![]() ![]() ![]() |
Thanks John,
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Yes you could order it for a SE/HSE from L/R as a Exterior Design Pack cost about 3k, whether it was fitted at the Factory or a Dealer Fit I'm not sure.
Autobiography Exterior pack, does that mean all the other Internal etc additions for the Autobiography model, isn't included Col? So still not getting a "full" Autobiography specification, which wouldn't be much of a increase in price secondhand I presume, as most extras don't seem to be allowed for, more when trading in. |
Hi John,
Thanks a lot Col, most helpful as usual. |
Thanks folks,
I can only base a genuine A/B model based on my own, Externally the Front and Rear bumpers are different, as are the Rear Spoiler, Exhaust Tail Trims, Front Grill and Side Vents also the Door Handles and Side Mouldings are Colour Coded all though these could be painted on a HSE.
The Stop/Start button on later RRS1 models 2011 up to 2013, keyless models, when the new model came out is purely a button to Start and Stop the ignition, there is no shut off at lights or when stationary, in neutral or park. Hope that helps.
The RRS HSE with autobiography kit I was asking about - http://www.m-lionmotorgroup.co.uk/used-car...5103809819
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 ![]() ![]() |
My 62 plate rrs1 was an hse luxury and came with the exterior pack factory fitted.
If you are only doing 4/5k mls. a year buy a 5.0 S/C that will put a grin on your face |
The first of the other two AB models is pre 2011 as it still has stick gear change indicating 6 speed gearbox not the newer and more efficient 8 speed version. Only has 19" wheels, after facelift (2011) they were bigger, no flapper gear change. Many other differences, so you are getting an older car for not much less money. The tailgate won't be the newer one piece aluminium lightweight one.
The Rear Entertainment System is a After Market fit so could get that fitted to any vehicle for 1- 1.5k.
