Home > Technical > Leeds or Yorkshire based EGR blanking and remapping contact?
Page 3 of 3 <123
johnb8538
Cheers Mikey, you are of course telling me what my brain is still trying to avoid Laughing
There's a great step by step guide on the Disco forum which even I could manage as long as its done nice and steady.
Valves on fleabay are showing as £420 a set from Maltings, or £160 each from London both claiming to be genuine parts.
I believe I need gaskets as well.
Any other advice?
Post #500710 Tue Jul 12 2016 10:11pm
Disco_Mikey
£420 is borderline cost price for a pair of valves. There are also 3 gaskets per side needed to fit Thumbs Up
Post #500717 Wed Jul 13 2016 5:55am
johnb8538
Attended the Alive tuning agent as arranged, couldn't find their unit at first and they graciously sent a chap out to find and escort me in. Landrovers all over the street and clearly a busy place despite its backstreet run down appearance. £54 lighter for a diagnostic and told the same as I already knew, never mind the £30 in diesel getting there and back. To be fair they confirmed it was only one EGR on the drivers side and that the hoses were all spot on. For £550 they could fit a replacement if I came back another day next week. Strangely they wouldn't give me a quotation and just scribbled some prices down on paper but wouldn't let me have that either.
After a two hour wait they confirmed my "European engine was not suitable for blanking and remapping". Wish they had told me that last Saturday instead of all the messing about. They had quoted £274 for an EGR valve but I picked one up today at Malting's in Doncaster for £225 including gaskets which I intend to fit this weekend. Car is now in constant limp mode of 30mph and after 70miles additional motorway journey today in the slow lane being overtaken by forty footers it looks like I'll be waving this old girl on to pastures new. Certainly would have another rover but newer with less miles.
I'll let you know how the fit goes in case its useful to anyone.
Post #500757 Wed Jul 13 2016 8:21pm
johnb8538
EGR fitted by myself using a very good step by step guide. Technically it wasn't that complex just very fiddly in parts but I'd certainly do it again. The EGR was blocked so much it stuck open. The inside of pretty much every hose and pipe on the drivers side was caked in soot. I scrubbed what I could and used some carbon cleaner spray on the MAP and MAF sensors.
Well everything fired up straight away which was good, the EML light disappeared but the Restricted Triangle stayed on. Lots of carbon smoke poured out but cleared quickly and I guess the system will be clogged for a while yet. Filled the tank and took it up the A1 from Leeds to York, Restricted Triangle stayed on but performance was fantastic, acceleration great.
After an hour walk around we headed home and suddenly I realised the Restricted Triangle had gone. No dash lights, excellent performance-amazing. Sadly after ten minutes all hell broke loose- traction control warning, emergency brake failure, restricted triangle back. Stopped reset and all fine until I accelerated to 50mph then dash lights again.
So that's were I stand, drives fantastic unless I accelerate to fifty, I'm guessing its still clogged a bit. Any ideas?
Post #501085 Sun Jul 17 2016 10:40pm
johnb8538
The offending EGR (grrrr)
Exactly as I found it, stuck open. The devastation it has caused is unbelievable.
Post #501087 Sun Jul 17 2016 10:47pm
Johnski
I remember having to clean or blank off several EGRs on Rover 75s and MG ZTs, which gave owners an additional boost of extra power. Unfortunately the newer cars, this cannot be done to, which is a shame, the cars mentioned all passed every MOT, so all the efforts to make us greener, just cost more on purchasing new cars, and cost in extra fuel/performance. I think crazy world now, with all the extra things fitted, can't chop out the cats any more now on modern cars, although on previous mentioned, made no difference at passing MOTs, but technically should have. Whistle Big Cry
Hope you can get yours sorted, but if the pipes and EGR are still clogged, they would quickly interfere with signals to MAF sensor, causing more problems, this use to be a regular reason to replace through lack of power etc, try unplugging to see if it improves, you will get smoke and use more fuel, but can indicate if knackered. Wink John
Post #501088 Sun Jul 17 2016 10:58pm
Nothing to see here.....Responded to an old comment Embarassed ON THE WAY: BMW F21 M140i
Post #501105 Mon Jul 18 2016 11:06am
johnb8538
FINAL POST
Checked the rear air hoses at the back of the engine top (the short ones) and noticed they didn't seem to be centred in their spacing. Closer inspection showed an obvious air gap and with embarrassment I re-sited them then tightened them up. Could have slapped myself stupid as I then drove effortlessly up the motorway with a clear dash. Rolling with laughter
Note to self- Check, check, then check again!
Thank you everyone for all your help and advice.
Post #501310 Wed Jul 20 2016 8:11pm
Page 3 of 3 <123
