Home > Technical > can anyone answer this ......
nosmokenopoke
United Kingdom 2009 Range Rover Sport TDV6 Autobiography Zambezi Silver
Hi all.
There must be someone out there who has got a diagram of how to install the trigger wheel to a 2.7 tdv6.
Yes I know I need the tool but I want to see if mine is totally In the wrong place so it gives me a little hope before taking gearbox out.
I set the hole on the trigger wheel in perfect centre of the crank signal sensor....... anyone ☺
Post #500712 Wed Jul 13 2016 2:32am
Disco_Mikey
And at what position did you align the trigger wheel in the crankshaft?
The tool only fits one way onto the crank, and attaches to the tool in only 1 way to ensure perfect alignment
Post #500716 Wed Jul 13 2016 5:48am
nosmokenopoke
Hi again ☺
I put the dot directly inline or in front of the sensor
Cheers Jon
Post #500737 Wed Jul 13 2016 12:45pm
Disco_Mikey
Yes, and at what position was the crankshaft in when the ring was fitted
Post #500753 Wed Jul 13 2016 6:12pm
nosmokenopoke
Hi Mike
It was locked out with timing kit. So tdc or set for cam belt
Thanks Jon
Post #500755 Wed Jul 13 2016 7:23pm
Disco_Mikey
I do believe you have the trigger wheel approx 180 degrees out
Post #500756 Wed Jul 13 2016 7:41pm
nosmokenopoke
Mike do u have the tool ? If so am I 180 degrees out being the perfect degrees ? If yes then I would take the gamble on doing it again but without the tool. Paying 200 odd quid for a piece of metal seems a little steep.
I got a 2 post spare ramp that this junk has been sat on for the last 6 months so it's not like it's in my way and taking a gamble with body off I'd rather save the 200 quid. I can get the body off in no time as I only parcially put it down.
3k in so every penny counts.
Thanks
Jon
Post #500762 Wed Jul 13 2016 11:23pm
Disco_Mikey
I don't have the tool. From what I have seen, it sounds as though your trigger wheel is APPROX 180 degrees out.
If you are already £3k in, what is another £200? Confused
You could always sell the tool on again, as a lot of people seem to have exactly the same issue Wink
Post #500768 Thu Jul 14 2016 7:00am
