Home > Technical > TDV8 Suspension red light on and significant oil loss |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
If the ACE bar was leaking and you now have no oil in the reservoir its the first place I would look for the source of the leak.
Tue Jul 12 2016 10:25pm |
dmorris66 Member Since: 17 Jun 2015 Location: wixford Posts: 6 |
Thanks Rob.
Tue Jul 12 2016 10:40pm |
johnb8538 Member Since: 04 Aug 2015 Location: Glasshoughton Posts: 24 |
Although mine is a 2010 model I had a similar issue last month. the o rings on the supply pipes are your first easy check but like me you might have a slightly fractured hydraulic pipe. A doable self repair but I was lucky to have access to a pit and a helpful father in law with a compressor. My pipe was £200 from Landrover (dealer only) which came with the o rings!
Tue Jul 12 2016 10:47pm |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 8940 |
How far is the garage away? Might be worth topping up the oil so that the pump isn't run dry. A new DR pump on top of a new DR bar would be annoying.
Wed Jul 13 2016 10:03am |
Hi
Mon Jul 18 2016 2:33pm |
Thats probably the better news then as not the bar itself I resume the diagnosis is a damaged pipe (not sure how that has happened) or a leak further up the line
Tue Jul 19 2016 9:19pm |
The TDV8 has a two piece pipe, I think, so replacement should be relatively painless. 2012 SDV6 - it's missing a couple of cylinders
Tue Jul 19 2016 9:40pm |
Update!
Thu Aug 18 2016 1:43pm |
