Home > General > Leaking ARC bar |
Chris80 Member Since: 05 Oct 2015 Location: Kent Posts: 58 |
I've just noticed my front one has started to leak.
Wed Apr 27 2016 3:38pm |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 |
Thanks Chris, following your suggestion I have searched this topic & it seems it could be a cheap O-rings replacement issue. So...I have e mailed the garage asking to check the O-rings before getting stuck into what is the expensive option!
Wed Apr 27 2016 4:17pm |
You never know!
Wed Apr 27 2016 8:01pm |
URX Member Since: 09 Feb 2009 Location: Edinburgh Posts: 194 |
Mine went on 2nd RRS and was fortunately 6weeks inside warranty
Wed Apr 27 2016 10:19pm |
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 |
Yep, mine was noticed when car was serviced. 1500 quid for the rear unit replacement. Thankfully under warranty. 2010 TDV8 |
Thu Apr 28 2016 5:51am |
Rich Member Since: 14 Nov 2014 Location: West Sussex Posts: 39 |
Mine too. 2010MY. Dealer picked it on service, fortunately just before "approved used" warranty ran out.
Thu Apr 28 2016 7:24am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8980 |
My rear bar was replaced three or four years ago. Thankfully under warranty at the time. 2012 SDV6 - it's missing a couple of cylinders
Thu Apr 28 2016 8:38am |
Thanks all, it seems to be rather more common than I thought... Cross fingers for simple O-rings as I'm only 50% covered on ARC bars |
Thu Apr 28 2016 10:04am |
htc Member Since: 10 Jan 2016 Location: beds Posts: 15 |
My 2010 MY started leaking when the car was 5 years (55k miles) old and replaced.
Fri Apr 29 2016 7:44am |
Danv8 Member Since: 20 Apr 2015 Location: Norfolk Posts: 378 |
My front was replaced last year £1600, my rear was reported to be weeping when it had its mot in march. When booked in to the dealers for the service and cambelt and for the investigation they advised me to leave it for a year or so. There reply was they've had many in with much more of a leak than i had and not to worry about it. |
Mon May 16 2016 12:53pm |
Where was it weeping from? If the pipe connections then it might be a simple and cheap fix. Leaving it might end up causing damage that does require a bar to be replaced. 2012 SDV6 - it's missing a couple of cylinders
Mon May 16 2016 4:51pm |
Well the upshot was rear bar replacement not just the o rings. Await the bill but warranty paying half |
Mon May 16 2016 5:36pm |
Not sure think it was where the ARB entered the actuator, as it was the Actuator that had a fine mist of oil on it. Didnt actually see it for myself. |
Tue May 17 2016 8:58am |
Alexelluk Member Since: 30 Apr 2011 Location: Fife Posts: 22 |
Hi folks,
Sat Jul 02 2016 3:05pm |
