Home > General > Leaking ARC bar
Timf
United Kingdom 2010 Range Rover Sport TDV8 HSE Galway Green
Leaking ARC bar
Has anyone had their rear ARC bar leak oil? Mine is, and that explained the red warning light coming on telling me to stop a few weeks ago as the reservoir was empty.
I had the reservoir topped up and the garage found the leak - light oil all over the underside rear. They told me its rare for this to happen and the remedy is well into four figures. Luckily I'm warrantied but annoyingly only 50% for ARC bar!!
Anyone had it happen?
Post #494558 Wed Apr 27 2016 3:01pm
Chris80
United Kingdom 2008 Range Rover Sport TDV8 HST Stornoway Grey
I've just noticed my front one has started to leak.
If you do a search, you will find that its quite a common problem!.
Chris Thumbs Up
Post #494564 Wed Apr 27 2016 3:38pm
Timf
Thanks Chris, following your suggestion I have searched this topic & it seems it could be a cheap O-rings replacement issue. So...I have e mailed the garage asking to check the O-rings before getting stuck into what is the expensive option!
Many thanks again, here's hoping Thumbs Up
Post #494567 Wed Apr 27 2016 4:17pm
Chris80
You never know!
I did the same, but mines leaking from the unit itself so a replacement for me!
Hopefully it's a cheap fix for you
Chris Thumbs Up
Post #494608 Wed Apr 27 2016 8:01pm
URX
Scotland
Mine went on 2nd RRS and was fortunately 6weeks inside warranty
Otherwise
Id have been feeling very very poor RRS1 2009 - 2012
RRS1.5 2012 - 2016
RRS2 ...you are kidding right?
Post #494631 Wed Apr 27 2016 10:19pm
Stecla
England 2010 Range Rover Sport TDV8 HSE Stornoway Grey
Yep, mine was noticed when car was serviced. 1500 quid for the rear unit replacement. Thankfully under warranty. 2010 TDV8
Post #494638 Thu Apr 28 2016 5:51am
Rich
Mine too. 2010MY. Dealer picked it on service, fortunately just before "approved used" warranty ran out.
I think I was told it was something to do with poor O rings on original, improved on later versions.
Post #494641 Thu Apr 28 2016 7:24am
My rear bar was replaced three or four years ago. Thankfully under warranty at the time. 2012 SDV6 - it's missing a couple of cylinders
Post #494647 Thu Apr 28 2016 8:38am
Timf
Thanks all, it seems to be rather more common than I thought... Cross fingers for simple O-rings as I'm only 50% covered on ARC bars Sad
Post #494657 Thu Apr 28 2016 10:04am
htc
United Kingdom 2010 Range Rover Sport TDV8 HSE Buckingham Blue
My 2010 MY started leaking when the car was 5 years (55k miles) old and replaced.
I have read that experienced tech's are able to replace the unit by raising the body work by a few inches avoiding an expensive full body lift.
Post #494723 Fri Apr 29 2016 7:44am
Danv8
United Kingdom 2009 Range Rover Sport TDV6 HSE Lux Alaska White
My front was replaced last year £1600, my rear was reported to be weeping when it had its mot in march. When booked in to the dealers for the service and cambelt and for the investigation they advised me to leave it for a year or so. There reply was they've had many in with much more of a leak than i had and not to worry about it.
Post #496197 Mon May 16 2016 12:53pm
Where was it weeping from? If the pipe connections then it might be a simple and cheap fix. Leaving it might end up causing damage that does require a bar to be replaced. 2012 SDV6 - it's missing a couple of cylinders
Post #496209 Mon May 16 2016 4:51pm
Timf
Well the upshot was rear bar replacement not just the o rings. Await the bill but warranty paying half Crying or Very sad
Post #496214 Mon May 16 2016 5:36pm
Danv8
Not sure think it was where the ARB entered the actuator, as it was the Actuator that had a fine mist of oil on it. Didnt actually see it for myself.
Post #496260 Tue May 17 2016 8:58am
Alexelluk
Scotland 2009 Range Rover Sport TDV8 HSE Stornoway Grey
Hi folks,
Not on very often as I have my 2010 RR Sport 3.6 TDV8 for 5 1/2 years with no major problems/costs. Very Happy The motor has just passed mot again with no work required. Razz The independent land rover dealer pointed out I had a minor oil leak/weep from the rear arc bar but did not think it would be repaired under warranty. I have land rover extended warranty and was wondering if anyone else has managed to get the repair carried out under warranty.
Cheers Alex
Post #500050 Sat Jul 02 2016 3:05pm
