![]() | Home > Faults & Fixes > Need help!! |
alex3357 Member Since: 09 Mar 2015 Location: Bayton Posts: 10 ![]() ![]() ![]() |
Hi Benji
benji1988 Member Since: 29 Jun 2016 Location: Manchester Posts: 10 ![]() ![]() |
They all came at the same time so was thinking it was some sort of sensor or something... And from what I can see there's no oil and its was a dry when the fault came up. Where on the car would I find that part?
It could be a sensor.
I'll have a look later don't think it's the anti roll bar (hope not :/ as it looks expensive) as I've not seen any oil anywhere. I'll keep you posted tho
Permanent lowering can be done BUT it isn't recommended as it makes the ride rock hard, can wear out steering and transmission components more rapidly and can cause accelerated tyre wear. It's an off-road vehicle so what's the point anyway? BTW if you can get it above 100mph for more than 5 secs it will lower automatically anyway for stability purposes....... 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Checked all the above and can't see anything wrong. As if by magic all faults have gone off the dash, had it plugged and checked no codes found, so not sure what to do next. |
If all the codes have gone could be down to a comes glitch. Since nothing stopped to car would continue to drive as normal and see if it happens again.
rigsby Member Since: 20 Apr 2012 Location: Portsmouth Posts: 879 ![]() ![]() |
Silly question but have you got a rear bulb out, either side light or brake light as these can throw up all sort of errors !! MY16 AUTOBIOGRAPHY Indus silver with some toys
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
sounds like battery playing up
No, no bulbs out or anything. Strange.... Everything's been alright since just have to wait and see. Dose anybody know if it will take the white LED number plate lights as I've been told they might not take um and could start chucking warning lights up on the dash (any truth in it) cars a 10 plate 3.6 tdv8 |
If any LED bulbs aren't the official ones, where used, you have to ensure the LED has a resistor on it, without this it causes all sorts of error lights and codes, as you have said. Unfortunately that is true.
Easy just go on Amazon tap in 501 led canbus error free, had them in mine for 3 years no problem, replaced the front side lights with the same.. Also replaced with the same in my wife's my10 plate Freelander 2 and my parents my09 Freelander 2..
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
Sounds like you have a range rover sport! spiteful Range Rover Sport tdv8 |
I have them in mine and as said here make sure you get error free and read the advert to make sure they are suitable Rear led bulbs in the tails make the indicators flash fast on the dash but not the actual outside |
