Home > Technical > Brembo brake problem
Steveo
Hi all, a couple of weeks ago I bought new front discs and pads for my 2006 Range Rover sport tdv6 HSE, at the weekend I finally had time to fit them but when I tried to put the new pads back in the caliper the outside pad fitted in as normal but the inside pad wont go in as its to tight to the disc!! I have brembo calipers on the front and I did ask them at the shop if I needed brembo discs and they said that I didn't so can anybody tell me if this is true, have the brembo discs got a different offset to bring the disc central to the brembo calliper?
Post #499876 Wed Jun 29 2016 8:21pm
shakeapaw
Ive not had that problem with either aftermarket pads or disc, have you pushed the pistons back in? 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater Smile)))
Post #500038 Sat Jul 02 2016 9:44am
Olly-ibiza
Has the piston gone right back so its almost flush with the caliper? They suffer with corrosion on the pistons and it stops them going all the way back spiteful Range Rover Sport tdv8
Post #500071 Sat Jul 02 2016 9:17pm
Steveo
Thanks for replying guys but yes the pistons are all the way in, I only rebuild them last year so there working fine now that's why I'm changing the discs because the calipers sized and warped the discs, when the caliper if fitted with no pads in you can clearly see it's not central 🤔
Post #500076 Sun Jul 03 2016 12:42am
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Don't know about RRs Brembos yet but thats whats on mine. On other cars the calipers are 'floating' they move on slides.
If this is the case the slide pins may be sticking and need to be removed , cleaned, inspected lightly coated with CFC and checked for movement. Then it just might be a case of getting the caliper in the right spot. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #500100 Mon Jul 04 2016 8:07am
Steveo
Thanks for your reply but the brembos just bolt straight on there's no sliders there a fixed unit unfortunately:(
Post #500181 Tue Jul 05 2016 12:15pm
tonywolf
United Kingdom 2013 Range Rover Sport SDV6 Autobiography Orkney Grey
Excuse my ignorance, but what is CFC?
Steveo, are these 4 or 6 pot Brembo's. I only ask as I fitted 6 pots at the weekend, and as you say they bolt directly to the hub and they can only go on one way. I just pushed the pistons flush to the caliper body and the pads just dropped in. Best Regards
Tony
MY2014 SDV6 AB Dynamic
Post #500226 Wed Jul 06 2016 6:50am
Thought it was CRC a spray lubricant bit like our WD40. Thought CFC was the propellant gas used in things like aerosols.
Post #500228 Wed Jul 06 2016 7:27am
Steveo
Yeas they are 6 pot Tony, have you got brembo discs as well?
Post #500256 Wed Jul 06 2016 12:36pm
tonywolf
Well I have the LR discs off the 5.0 sc Best Regards
Tony
Post #500257 Wed Jul 06 2016 12:43pm
