Home > Technical > HDC Fault, Transmission Fault, Special Programs Not Availabl |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Brake bulbs? 2012 SDV6 - it's missing a couple of cylinders
Tue Jun 14 2016 8:21pm |
Gibbsy1966 Member Since: 25 Apr 2012 Location: Derbyshire Posts: 73 |
Had this issue on a 2005 s/c if I remember rightly it was caused by a simple brake switch....cost about £20 to sort BMW 530D 2011 still here
Tue Jun 14 2016 8:54pm |
Harry HST Member Since: 09 Feb 2010 Location: Birmingham Posts: 296 |
Brakes bulbs all working perfectly fine.
Wed Jun 15 2016 10:48am |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 |
Alternator on the blink ?? 2007, HSE, Cairnes Blue, Factory tints, Love it !!! |
Wed Jun 15 2016 12:21pm |
Brake switch replaced still the same problem! |
Sat Jun 18 2016 12:11pm |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 |
From my experience and research
Wed Jun 29 2016 5:02pm |
junior Member Since: 02 Feb 2016 Location: Sheffield Posts: 44 |
I get the same message but only occasionally. It seems to occur when I haven't used the car for a week or so. I was suspecting low charge on the battery triggering the message as when its had a good run for a few consecutive days it doesn't occur. Don't ask me why or how but that's how it seems to work. |
Wed Jun 29 2016 5:28pm |
Oh yes, as junior says this can also be battery related / alternator
Wed Jun 29 2016 5:43pm |
TDV888 Member Since: 29 Jun 2016 Location: London Posts: 11 |
Hi there,
Wed Jun 29 2016 5:51pm |
Welcome to the forum but Please read this thread from the start as we have all taken the time to reply with suggestions and personal experience.
Wed Jun 29 2016 5:55pm |
What did you do to resolve the problem you had? |
Wed Jun 29 2016 5:58pm |
Looking at the cars 4x4 info it showed front wheel was slightly right when I had steering wheel straight ahead. So the car couldn't understand when I drove why this was and locked off all functions... and gave the 3 amigos aka Hdc fault.
Thu Jun 30 2016 3:34am |
Guys just to add a quick note which may be helpful for someone someday as this problem is a nightmare..
Thu Jun 30 2016 3:35am |
Thanks for sharing your experience, as it goes my steering wheel is already slightly to the right when I drive straight.... Maybe having the wheels aligned and steering reset is a starting point, just before I bought the car apparently it had new bushes all round so failing that it could be a damaged sensor ect.
Fri Jul 01 2016 10:31am |
