Home > Maintenance & Modifications > turbo vanes stuck
brgjohn
United Kingdom 2006 Range Rover Sport TDV6 SE Giverney Green
turbo vanes stuck
i have what appears to be a situation with my turbo vanes stuck after the car (v6 diesel 2005) stood around for some time.
My questions are : has anybody injected something like Forte diesel cleaner straight into the air intake (there is a sensor right in the centre top of the intake which makes an easy entry point?
is there any way of a more thorough clean without removal?
I'm a competent engineer but, for obvious reasons, trying not to have to remove the turbo!
Is there any way of accessing the actuator to check movement (i can't see any!)
Your valued technical replies are appreciated
Cheers John
Post #499759 Tue Jun 28 2016 2:30pm
erickwan
Malaysia
What about using Seafoam Deep Creep?
I wonder if anyone has used it to good effect.
Post #499763 Tue Jun 28 2016 3:28pm
The vanes or the actuator ?
Post #499765 Tue Jun 28 2016 4:18pm
brgjohn
hard to tell, but no turbo boost
Post #499801 Tue Jun 28 2016 9:25pm
Camelrock
Do you have fault codes ? Why do you think the vanes are stuck ? What are the symptom's ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #499802 Tue Jun 28 2016 9:34pm
brgjohn
serious lack of acceleration, my code reader won't access the RRS, so ran along to my local garage who accessed a turbo fault code (didn't write down which one ) .I'm very conversent with the old style of turbo ,but these moving vane type are new to me! Garage man said very common failure ,although research suggests they are not worn but stuck, so , i'm trying to find a way of unsticking them !
Post #499835 Wed Jun 29 2016 12:55pm
Camelrock
Did it go go back to normal after the codes where cleared ? Or is it a hard fault (won't clear ). If turbo some people have had some success lubbing and working the actuator rod, you can get to it by removing the heat shields in the wheel arch n/s. If that doesn't work then it will prob need a new turbo.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #499840 Wed Jun 29 2016 2:05pm
Lost for Words
Suggest you drop Steve Norman a PM and book a visit: http://www.rrsport.co.uk/forum/member-stevenorman.html Top guy all round and a the biggest expert you'll find.
http://www.tandsnorman.com/
Thumbs Up Visiting from DISCO3.CO.UK
Post #499841 Wed Jun 29 2016 2:12pm
brgjohn
I've removed the heatshields under the wing, the actuator appears to be engine side of the turbo and not visable.
It didn't go back to normal when the codes were cleared
Post #499881 Wed Jun 29 2016 8:43pm
Camelrock
You need to make a hook out of a coat hanger or welding wire and hook it over the rod then work it back and forth. It should move freely, spray with penitrating oil.. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #499887 Wed Jun 29 2016 10:19pm
brgjohn
thanks guys, i'll go and have a word with Steve Norman
Post #499924 Thu Jun 30 2016 4:22pm
brgjohn
long time in coming back, but with the bit of wire and a lot of lubrication the rod freed off and i now get turbo boost and no fault code. It does have however a huge flat spot when accelerating up hill .Flat to the floor fine ! is this normal for the v6 ?
Post #508121 Wed Oct 19 2016 5:35pm
