Home > Maintenance & Modifications > Random alarm not bonnet switch
Gilly1
hi, I've just bought 2006 HSE it's got few things I need to look into but that's for another day, 😉 the alarm randomly went of a couple times (early hours off course) went to investigate this morning and the bonnet switch electric connector has already been disconnected and bridged with small piece wire, SO my question is what els could be the cause of random alarm.
Just to mention it may or may not be relevant, the car wouldn't allow me to open with the key at first also tried the spare then after several attempts with both key it decided to open, car started fine Locked and unlocked several times and ok, went into hidden menu and checked battery state and ignition on 11.5v engine started 13.5v.
I new I missed something when I sold my other RR SPORT. Confusion, worry, sleepless nights, and most important raiding kids piggy banks & searching down back sofas for extra cash for parts & repairs. O THE JOYS. 😜
Post #499447 Sat Jun 25 2016 8:47am
You could try pressing the lock button on the key twice.
This disables superlocking and ultrasonics from memory (check manual) and see if that stops it going off.
Post #499465 Sat Jun 25 2016 12:48pm
Gilly1
Thanks Andy, will give that a go, probably won't find out until stupid o,clock in the morning if/when it decides to go off. Yawn Thumbs Up
Post #499471 Sat Jun 25 2016 2:21pm
Yes its not very helpful but something easy in the absence of other idea's.
I wonder if it stores a fault code for what caused the alarm to go off. Considering my 1993 car did I would hope the answer is yes.
In which case you could get the codes read.
Post #499472 Sat Jun 25 2016 2:46pm
Gilly1
Yes, I'm seriously thinking of investing in a IID tool because from what I've read it's always good to have & I want to re calibrate and slightly lower ride hight, it's at 200mm at each corner but it's just a bit to high for me.
Post #499495 Sat Jun 25 2016 7:35pm
Yeah I have an IID BT. Paid £400.
Nice bit of kit, Should have purchased one a little sooner.
Post #499502 Sat Jun 25 2016 9:20pm
Pufftmw
http://www.rrsport.co.uk/forum/topic43444.html?highlight=bonnet
How To on the bonnet switch
Post #499515 Sun Jun 26 2016 8:20am
Gilly1
Hi puff, thanks for the link, when I went to investigate after alarm went off the sensor connector had already been removed and short circuit had been done so shouldn't that mean if alarm goes off after short circuit process it's not the bonnet sensor, I've taken sensor off anyways and give it a good clean and refitted the electrical plug so see what happens. 👍
Post #499521 Sun Jun 26 2016 10:08am
