Home > General > Java Black |
Every chance you may have. There is T-Cut for Metalic and other finishes for this reason, I presume, did you use the standard version or one of the special versions of T-Cut?
Wed Jun 15 2016 9:18pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
You'd be able to see it if you removed the lacquer, t cut is quite abrasive and don't break down as you use unlike other cutting compounds.
Thu Jun 16 2016 12:01am |
junior Member Since: 02 Feb 2016 Location: Sheffield Posts: 44 |
I used t-cut for metallic paint but by the sounds of it should not be using this stuff at all. Can anyone recommend a product suitable for Java black or pearlescent paint in general?
Thu Jun 16 2016 9:10am |
Unless you want to pay silly prices for the 'boutique' products then just use Autoglym Super Resin Polish to get a good shine. 2008 MY Java Black TDV8 HSE
Thu Jun 16 2016 9:38am |
Paddi, I use the Autoglym stuff meself, its great value and polishes without leaving that annoying 3D haze. It's the scratch remover I'm after though, one that doesn't remove the lacquer in the process of removing the scratch. Any suggestions? |
Thu Jun 16 2016 2:43pm |
As anyone can see just by looking at my car - I am no detailing expert
Thu Jun 16 2016 3:26pm |
Yeah, thinking about it using a suitable wax polish is the best way to go to disguise the scratches - we're only talking superficial scratches anyway. The abrasive nature of any scratch remover, t-cut or whatever, is not going to do the clear coat any good. Cheers Paddi. |
Thu Jun 16 2016 6:10pm |
Jaggs Member Since: 09 Aug 2015 Location: Leeds Posts: 259 |
I use poor boys black hole with nattys black wax on top, hides a multitude of sins Nanocom Evo |
Thu Jun 16 2016 8:28pm |
