Home > General > Java Black
junior
Java Black
Whilst polishing my RRS a couple of weeks ago I managed to put a couple of hairline scratches on the wing. Never mind, I thought, I'll t-cut them out and re-wax the affected area. During the t-cutting I notice a little black paint on the cloth but thought nothing about it at the time. The end result looked fine so that was that, or so I thought.
However, a couple of weeks later I bought a can of Java black from Halfords to colour code the side vents and upon reading the instructions it advised that the finish should be lacquered as Java black is a pearlescent paint and is as soft as Censored.
So, the dilemma I have is did I lift-off the lacquer when I t-cutted the wing and expose the paint and should I get it in the paint shop and have it professionally re-lacquered before the paint gets damaged?
Post #498734 Wed Jun 15 2016 7:25pm
Johnski
Every chance you may have. There is T-Cut for Metalic and other finishes for this reason, I presume, did you use the standard version or one of the special versions of T-Cut?
Even the LR touch up paints come as set of two, with the top coat as well as paint. John
Post #498740 Wed Jun 15 2016 9:18pm
HemoRRS
You'd be able to see it if you removed the lacquer, t cut is quite abrasive and don't break down as you use unlike other cutting compounds.
If the paint looks an even colour itll be fine. Just give it a polish.
Post #498760 Thu Jun 16 2016 12:01am
junior
I used t-cut for metallic paint but by the sounds of it should not be using this stuff at all. Can anyone recommend a product suitable for Java black or pearlescent paint in general?
Thanks
Post #498786 Thu Jun 16 2016 9:10am
Paddi
Unless you want to pay silly prices for the 'boutique' products then just use Autoglym Super Resin Polish to get a good shine. 2008 MY Java Black TDV8 HSE
Post #498788 Thu Jun 16 2016 9:38am
junior
Paddi, I use the Autoglym stuff meself, its great value and polishes without leaving that annoying 3D haze. It's the scratch remover I'm after though, one that doesn't remove the lacquer in the process of removing the scratch. Any suggestions?
Post #498806 Thu Jun 16 2016 2:43pm
Paddi
As anyone can see just by looking at my car - I am no detailing expert Laughing
There is an Autoglym 'next step up' product called paint renovator but according to Chips Away - it is more abrasive than T-Cut which you've already tried.
https://www.chipsaway.co.uk/our-world/blog...-worth-it/
Have you tried applying a decent wax to the scratches - most have fillers in them that disguise minor scratches quite well? 2008 MY Java Black TDV8 HSE
Post #498808 Thu Jun 16 2016 3:26pm
junior
Yeah, thinking about it using a suitable wax polish is the best way to go to disguise the scratches - we're only talking superficial scratches anyway. The abrasive nature of any scratch remover, t-cut or whatever, is not going to do the clear coat any good. Cheers Paddi.
Post #498828 Thu Jun 16 2016 6:10pm
Jaggs
I use poor boys black hole with nattys black wax on top, hides a multitude of sins Nanocom Evo
Post #498843 Thu Jun 16 2016 8:28pm
