![]() | Home > General > Vibration and steering wheel shake |
Jimbob36 Member Since: 13 May 2016 Location: Melton mowbray Posts: 74 ![]() ![]() ![]() |
Me too! Had everything done. I suspect steering rack as prone on the first model tdv6. Only just got car so want sorting. |
l200jmc Member Since: 07 Mar 2015 Location: North East Posts: 16 ![]() ![]() |
Such and pain in the *** ain't they mate. Mines the tdv8 on a 57 but shes got a few miles now |
It's been back and had turbo actuator, 2 tyres, front discs, alignment and balancing. Still there! |
Loco98 Member Since: 06 Jun 2015 Location: Dublin Posts: 31 ![]() ![]() ![]() |
Have the same issues myself. Garage have tried everything to sort it. Suspension is fine. Rack is fine. Tracking and whelel balancing. Changed discs all round. EPB shoes. I think it's a sticky caliper myself but they said they are fine. Funnily though after the last time it was in I checked the wheel nuts a few were slightly loose. I tightened them up and did have a blast at the garage. Funnily about a week later I found 3 that had slightly loosened again. It's like a quater turn loose. Have ordered new wheel nuts. |
These cars are nothing but headache's or at least mine is lol, I've noticed I have a bit of play in the steering wheel, which can be felt when going over bumpy terrain.. If anybody knows what it could be |
mac01642 Member Since: 31 May 2016 Location: north east Posts: 20 ![]() ![]() ![]() |
currently going through the same, this only started happening after new brake pads where fitted.... following fitting I had a sticky caliper which cause dover heat. this weekend im changing discs and callipers. I will let you know how I get on. |
RRSTDV8 Member Since: 13 Aug 2011 Location: Northamptonshire Posts: 9053 ![]() ![]() ![]() |
Be helpful if you filled out your profile so we all know what version of RRS you're driving in future threads. ![]() My TDV8 is starting to feel loose in the steering too. I think it's getting ready for new struts (the ride is a bit brittle these days) and I'll probably throw new arms at it too. After 130,000 hard miles and nearly 9 years I think they're due a change. Although the front lower arms have been changed before I think a full set might be a good plan. In your place, I'd start with a new set of lower front arms. They're the usual wear items at the front end. ![]() 2008 TDV8 - it was a labour of love and is much missed |
Bounce Member Since: 12 Apr 2016 Location: Cornwall Posts: 21 ![]() ![]() ![]() |
I had all these issues after new pads were fitted,wheel vibration,sticking calliper etc.After 3k miles it seems to have sorted its self now,must of been a misshaped pad.By the way it's a 2006 2.7. |
What I have found with mine is that the wheels are losing balance after a couple of weeks. Got them balanced 2 weeks ago and all vibrations gone. Now they are now going out of balance again. What would make them keep losing balance. |
Same as ours was! Weve now lost patience with it and it has been rejected as not fit for purpose. Engine fault came back again after 2 weeks. Turbo, map, maf, csv all replaced and it still did it ! Most unreliable car we've owned! Won't be having another one! Back to defender td5 for us! |
BKHK Member Since: 05 May 2008 Location: Perth Posts: 1941 ![]() ![]() ![]() |
It sounds unlikely and it was the subject of many posts back in 08-09 however, my persistent front wheel wobble was eventually traced to the rear diff.
