Home > Technical > wrong fuel in |
Hamner Member Since: 28 Jan 2015 Location: Swansea Posts: 54 |
hi all , can someone help me with a problem for a RRS TDV6 2006 plate. Petrol was put in instead of diesel. A local garage got it running again - but it is now giving out white smoke, running really rough and the garage has said that it is showing an injector fault. Has anyone had a similar problem and how did they rectify it. Many thanks. |
Thu Jun 09 2016 11:49am |
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 |
Never done this myself but some threads here might help
Thu Jun 09 2016 11:56am |
LR Assist or most of all the major breakdown companies cover this, some car insurance companies offer it at a extra premium.
Thu Jun 09 2016 12:32pm |
LR only started fitting misfuelling devices with the introduction of the TDv8's in 2007MY unfortunately. 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it
Thu Jun 09 2016 1:42pm |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 942 |
I also thought all Rrs had the miscued device in the filler,,, tried mine out a couple of weeks ago( by accident), managed to get 26p worth of petrol in before it shut off. Good job the tank was empty,, just tanked it to the top after resetting the misfuel device. 2010 RRS, TDV8
Thu Jun 09 2016 1:59pm |
hi guys thanks for the replies , yes the engine was run for a short time |
Thu Jun 09 2016 5:04pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 8971 |
Not sure my MY08 TDV8 has the misfuel device...must admit to never having tried it though! 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Thu Jun 09 2016 5:58pm |
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 |
The biggest problem with misfueling is the high pressure fuel pump, to achieve the insane high pressure required for a common rail diesel engine the tolerances inside the pump are very small, the pump uses the diesel as a lubricant, if you have petrol in there that has no lubricating properties it basically wears the faces in the pump and leaves you with low fuel pressure spiteful Range Rover Sport tdv8 |
Thu Jun 09 2016 6:30pm |
My 2007MY did, it was a yellow plastic device that was in one of the cutouts in the polystyrene kit holder above the spare wheel. It was simple to use........... Push down the filler hole and reset the flap! 2020 Pangea Green 1st Edition D240 New Defender 110 is here and loving it 2018 Melting Silver Mini Countryman PHEV - soon to be replaced 2015MY Corris Grey SDv6 HSE Dynamic, the best car I have ever owned, totally reliable only a cou0le of rattles in 3 years, now no longer in my care Also in my garage is a 1996 TDi300 Defender 90 County HT made into a fake CSW |
Thu Jun 09 2016 7:22pm |
You can purchase them, not sure if they will fit all the earlier models though?
Thu Jun 09 2016 8:10pm |
hi all, it was,nt me who missfueled it was the MRS by the way |
Fri Jun 10 2016 3:39pm |
Oh yes - I would love a get out of jail card like that - I could use it for years Wanted a Series 2 LR since childhood but previously owned MY16 Disco Sport HSE TD4 Auto, MY13 RR Sport Black Edition TDV6 Auto, MY10 RR Sport HSE TDV6 Auto, 2007 Freelander 1 Freestyle TD4 Soft Top, 2009 Freelander 2 GS TD4 Auto, 2007 Freelander 2 GS TD4, 2004 Disco 2 Metropolis Auto, 2002 Disco 2 GS, 2000 Freelander 1 SE TD4 SW
Fri Jun 10 2016 4:18pm |
I checked today when filling up. The neck has no misfuel device in it. Odd. 2012 SDV6 - it's missing a couple of cylinders 2008 TDV8 - it was a labour of love and is much missed |
Sat Jun 11 2016 9:08pm |
