![]() | Home > In Car Electronics > Ejection trouble |
May I ask is this a single play unit or multiplayer? Thanks. John
It's the preface lift so is a multiplayer.. 2008 G4 RRSport TDV8 current
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, i'm no expert on this one but i had the same problem with mine, i just done a hard reset and it done the trick. Not sure if it will work for you but worth a try |
No GH the pin under the button has gone the button just flaps about so it's a mechanical fault, thanks for the reply though.. 2008 G4 RRSport TDV8 current
Hi, sorry mate, thought it was a electrical problem not a mechanical one... |
JOCK55 Member Since: 01 Sep 2015 Location: INVERNESS Posts: 415 ![]() ![]() ![]() |
I am no expert either, but I understand Viagra is very effective!!!!
No jock that's for inflation problems |
