Home > General > Back seat seems to be locked in folded down position?
Newstuart
Hi guys
Just been to the tip in my 2010 sport with the back seats folded fully down (ie the base hinged foward and the back folded down flat.for some reason the larger split side (passenger side) section seems to be locked in the down position so I cant lift it back up.
Anyone had this or any suggestions how to release it ?
Post #497752 Fri Jun 03 2016 7:59pm
PEACHY
Try putting a little weight on it - taking it past the lock out phase - this usually allows it to return Thumbs Up 16MY Estoril Blue SVR.............
Post #497754 Fri Jun 03 2016 8:11pm
TPS
You need to pull the lever to release the seat. The same lever you pull to lower it. -----------------------------------------------
RRS SDV6 HSE MY2012 Orkney grey, Oxford leather Ivory seats Ebony carpet, Anigre wood trim, enhanced design pack.
Post #497755 Fri Jun 03 2016 8:14pm
Newstuart
Thanks guys thats sorted it. i was pulling the lever but it wasnt releasing. Just climbed in and bounced up and down on it, tried the lever again and its worked. Not sure what the neighbours wouldve thout but job done.
Thanks again
Post #497757 Fri Jun 03 2016 8:18pm
PEACHY
Another happy member Thumbs Up 16MY Estoril Blue SVR.............
Post #497758 Fri Jun 03 2016 8:20pm
fkarim
I sometimes found the rear seat headrest if pushed hard against the folded up bench, stopped the rear seat from lifting back up. Moving the front seat a little forward helped. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
Gone: MY16 RRS2 3.0 SDV6 Autobiography Dynamic, Carpathian Grey & Santorini Black Sliding Pano/Ebony & Ivory 2 Tone
Gone: MY13 RRS 3.0 SDV6 HSE Black Edition, Orkney Grey/Ivory
Gone: MY09 RRS 2.7 TDV6 HSE, Santorini Black/Almond
Post #497759 Fri Jun 03 2016 8:23pm
