![]() | Home > General > Back seat seems to be locked in folded down position? |
PEACHY Member Since: 07 Nov 2010 Location: Birmingham Posts: 2795 ![]() ![]() |
Try putting a little weight on it - taking it past the lock out phase - this usually allows it to return |
TPS Member Since: 12 Oct 2015 Location: Buckinghamshire Posts: 127 ![]() ![]() ![]() |
You need to pull the lever to release the seat. The same lever you pull to lower it. -----------------------------------------------
Newstuart Member Since: 21 Feb 2016 Location: Northumberland Posts: 35 ![]() ![]() |
Thanks guys thats sorted it. i was pulling the lever but it wasnt releasing. Just climbed in and bounced up and down on it, tried the lever again and its worked. Not sure what the neighbours wouldve thout but job done.
Another happy member |
I sometimes found the rear seat headrest if pushed hard against the folded up bench, stopped the rear seat from lifting back up. Moving the front seat a little forward helped. Current: Volvo XC90 T8 Inscription Pro PHEV with some optionals on top
