![]() | Home > Maintenance & Modifications > Belt change procedure 4.2ltr |
sonnyjim Member Since: 22 Jun 2013 Location: Kent Posts: 131 ![]() ![]() ![]() |
Is there any info/threads/workshop manuals on changing the belts on the 4.2ltr SC engine?
Olly-ibiza Member Since: 23 Aug 2014 Location: Chester/Ibiza Posts: 189 ![]() |
The engine timing is on a chain on the 4.2SC spiteful Range Rover Sport tdv8 |
Hi Guys, sorry hould have made myself clearer, im aware the V8s cam chain driven, I meant the primary and secondly belts (V belts, aux belts) ones located at the front of engine. '06 RRS Supercharged Cairns Blue |
johnunleashed Member Since: 13 Jul 2014 Location: Lancashire Posts: 59 ![]() ![]() |
Hi better to remove the viscous fan , then on the left as you look at the engine is the supercharger belt tensioner its a 1/2 inch drive size , once that is off the other tensioner is on the right and its 3/8 drive size , easy job to do, once belts are fitted turn over engine by hand , just to make sure belts are sat correct , any thing else just ask 2007 SUPERCHARGED HST |
Ok thanks, do any of the plastic belt rollers or tensioner (if any) need replacing? Also how much tension is applied to the belts?
Spin the rollers by hand and check for play , the tensioner put the correct pressure on the belts , all done for you mate 2007 SUPERCHARGED HST |
Cheers mate |
