Home > Maintenance & Modifications > Belt change procedure 4.2ltr
sonnyjim
United Kingdom 2006 Range Rover Sport Supercharged Cairns Blue
Is there any info/threads/workshop manuals on changing the belts on the 4.2ltr SC engine?
Done a few searches and not a lot seems to come up for that engine.
Sonny '06 RRS Supercharged Cairns Blue
Post #497681 Thu Jun 02 2016 11:17pm
Camelrock
Not 100% but i'm sure I've read on here that the s/c are chain or do you mean the supercharger ? 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #497694 Fri Jun 03 2016 9:26am
Olly-ibiza
The engine timing is on a chain on the 4.2SC spiteful Range Rover Sport tdv8
Post #497706 Fri Jun 03 2016 12:30pm
sonnyjim
Hi Guys, sorry hould have made myself clearer, im aware the V8s cam chain driven, I meant the primary and secondly belts (V belts, aux belts) ones located at the front of engine. '06 RRS Supercharged Cairns Blue
Post #497709 Fri Jun 03 2016 1:09pm
johnunleashed
2007 Range Rover Sport Supercharged HST Java Black
Hi better to remove the viscous fan , then on the left as you look at the engine is the supercharger belt tensioner its a 1/2 inch drive size , once that is off the other tensioner is on the right and its 3/8 drive size , easy job to do, once belts are fitted turn over engine by hand , just to make sure belts are sat correct , any thing else just ask 2007 SUPERCHARGED HST
Post #497719 Fri Jun 03 2016 3:13pm
sonnyjim
Ok thanks, do any of the plastic belt rollers or tensioner (if any) need replacing? Also how much tension is applied to the belts?
I did have a look at the online service manual thingymajig but cant seem to find a step by step procedure '06 RRS Supercharged Cairns Blue
Post #497722 Fri Jun 03 2016 3:53pm
johnunleashed
Spin the rollers by hand and check for play , the tensioner put the correct pressure on the belts , all done for you mate 2007 SUPERCHARGED HST
Post #497724 Fri Jun 03 2016 4:33pm
sonnyjim
Cheers mate Thumbs Up '06 RRS Supercharged Cairns Blue
Post #497753 Fri Jun 03 2016 8:11pm
