Home > Maintenance & Modifications > New ARB bushes |
fdhadi Member Since: 17 Feb 2015 Location: Wigan Posts: 180 |
Hi Salisburylander
Mon May 30 2016 10:42pm |
harrygh60 Member Since: 16 Nov 2011 Location: London Posts: 395 |
I was quoted £150 For new front bushes fitted to ARB with Ace system, By a indie in Hainalt Essex The body needs lifting to remove the brackets. I believe the non Ace system is easier, no body lift itisme |
Tue May 31 2016 9:06am |
Not sure where the rumour started but you don't need to lift the body to change the front ARB bushes, you do need to lift the diff slightly.. |
Tue May 31 2016 10:20am |
Fish Member Since: 29 Jan 2014 Location: Glasgow Posts: 60 |
With the assistance of a cut down socket welded to the ring end of a ring spanner (to get at the passenger side clamp bolts) all was done on the drive way with not too much of a problem other than a bit of spanner rash on the knuckles. No lifting diff, splitting drive shafts etc. Oh, and I have ACE fitted. 2.7 HSE, Audi A6 Exec, Honda Accord Exec, Volvo 440, Volvo 360 |
Tue May 31 2016 11:13am |
ozzievechi Member Since: 14 Mar 2016 Location: london Posts: 55 |
hi, what garage was it, Les Paul Motors? need to get mine done and 150 doesn't sound too steep. How long will it take to do? |
Tue May 31 2016 12:02pm |
Salisburylander Member Since: 16 Mar 2014 Location: Salisbury Posts: 245 |
The work was done by an independent garage in Salisbury. The parts were £70 but I'm not sure about how much the cost was for just doing the ARB's as I had it serviced too. |
Tue May 31 2016 2:31pm |
jcw Member Since: 04 Jan 2016 Location: Gloucestershire Posts: 8 |
Had mine done at James French including new drop links for just an hours labour, I supplied the parts. |
Wed Jun 01 2016 6:22pm |
