![]() | Home > In Car Electronics > No sound |
Timf Member Since: 27 Feb 2010 Location: East Anglia Posts: 312 ![]() ![]() ![]() |
Is it still no go? I had the same. Overnight I left it & it came back |
nozz Member Since: 17 Jun 2015 Location: wakefield Posts: 39 ![]() ![]() ![]() |
Yes mate it's still same tried disconnecting battery aswell,had it on diagnostics and it comes up with audio control module |
dpg123 Member Since: 24 Mar 2016 Location: London Posts: 54 ![]() ![]() |
I understand this issue is linked to a static issue for which there was a Technical Service Bulletin. It's something to do with a voltage spike in the amp upon start up. I had this issue and spoke to Land Rover directly and they advised there is an official repair (a software update) which is free at your local dealer. I'd get in touch, check if yours has been updated and if not book it in. |
cheers,just phoned explained everything,they say theres no update, |
I've been told that before, but I had the number and details of update, I don't think they bother to look properly, as they miraculously then found it. |
I'll see if I can find any more details of update |
Best of luck, otherwise ask the member if he has the details of what LR said it was if possible. John
Hi again,
cheers ill try next week |
Guyzer73 Member Since: 04 Jul 2009 Location: Muscat Posts: 852 ![]() ![]() ![]() |
Another TSB but only for the US was LTB00179NAS2. Basically they state loss of audio with possible frozen touch screen on LR logo.
found out what it is , its the red/orange wire that goes up to the display if i wiggle it radio comes straight on just need a way to keep it on |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 ![]() ![]() ![]() |
When I took my screen and dvd unit out I saw there is an optical wire which need to be in and possibly clean also all wires in the back could do with removal and blow and insert same goes for wires in dvd unit under passenger seat.
