Home > Maintenance & Modifications > Front Dynamic Anti-Roll Bar Replacement |
RobP Member Since: 21 Jun 2009 Location: Kent Posts: 280 |
Great cheers for the reply, going to try the Disco Mikey method first but if not will be hoping I can get Geoff (who worked his magic on my gearbox) to plug his machine in TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten |
Sat May 07 2016 9:35pm |
Finished today, wow that was a pig of a job!
Sat May 21 2016 9:49pm |
joboco Member Since: 13 Sep 2021 Location: Scotland Posts: 24 |
Very old post I know but does anyone have a link to Disco Mikey bleed method for the front ACE |
Wed May 18 2022 5:26pm |
The bleed method is as I described above
Wed May 18 2022 9:54pm |
alfapat Member Since: 25 Sep 2021 Location: Elgin Posts: 210 |
Looks like I may be in trouble here. Just replaced front pipes and there is no sign of any movement in the reservoir. I hoping air is doing this , particularly that I replaced the front section pipes. |
Thu May 19 2022 10:36pm |
Trying to pinpoint where I should start and find out why I see no movement in the fluid level after replacing the front pipes, only fault code C1119-09 Now that relates to pressure and the orange indicator comes on the dash and can disappear after ign switch off, and doesn't always come back , nevertheless it's there. Would it be that one of the solenoid valves are not energising. Could do a manual test and energise, and the fact that , if this is the case the fluid is stuck the circulation path. There is no noise as in pump noise .
Fri May 20 2022 7:29am |
Yeah I have all that printed off .
Sat May 21 2022 11:05pm |
