Home > Maintenance & Modifications > Front Dynamic Anti-Roll Bar Replacement
Chilly07
Australia
Hi,
i have a leak from the Hydraulic seal. Have ordered a new Anti-roll bar. Looking to fit myself at home.
Has anyone done this?
Advice on how and what to look out for.
Estimate time to do?
Removing hydraulic pipes...special tool required?
What about bleeding the Hydraulic afterwards?
Any advice would be appreciated.
Thanks
Chilly
Post #486079 Sat Jan 30 2016 4:51am
I believe it's a body off job - or at least a body lift-a-bit anyway. 2012 SDV6 - it's missing a couple of cylinders
Post #486184 Sun Jan 31 2016 11:22am
harrygh60
England 2010 Range Rover Sport 3.0 TDV6 HSE Fuji White
Yes the ACE ARB Bush clamps have 3 bolts on each. And the rear one is imposible to get a socket onto it. So i think its a body lift job. Big Cry Big Cry itisme
Post #486186 Sun Jan 31 2016 11:56am
Just had a look at the manual. Assuming you have a 4.2S/C, I've extracted the procedure and put it here:
http://www.rrsport.co.uk/gallery/albums/us...0Sport.pdf
Doesn't need the body lifted but then they have special tools for the bush bolts. If you don't have those then you probably need to lift it slightly to get to the bolts as already noted. 2012 SDV6 - it's missing a couple of cylinders
Post #486189 Sun Jan 31 2016 12:07pm
Disco_Mikey
Front or rear bar?
Post #486196 Sun Jan 31 2016 1:04pm
harrygh60
I was refering to my Front Bar, I understand the rear
one is quite easy.? But i haven't looked Whistle itisme
Post #486197 Sun Jan 31 2016 1:09pm
Chilly07
Australia
Oops!
Should of stated:
TDV8 2008.
Front bar.
Post #486203 Sun Jan 31 2016 2:26pm
Disco_Mikey
Undo ARB links
RH clamp needs removed fully
LH clamp needs the front 2 bolts out, and the crossmember removed
Undo pipes
And it will come out at that. However...
If you remove the LH lower wishbone from the chassis, it makes things so much easier
Allow a full day to replace
There is a diagnostic procedure to bleed the system, but I have heard of some just fitting the bar, top up the system, and throw it around a little to get the system working, then opening the bleed nipples to bleed Thumbs Up
Post #486205 Sun Jan 31 2016 2:39pm
You make it sound so simple! Rolling with laughter Thumbs Up 2012 SDV6 - it's missing a couple of cylinders
Post #486259 Mon Feb 01 2016 8:55am
Chilly07
Australia
Disco_Mikey wrote:
Undo ARB links
Undo pipes
Thanks for this information.
Ill be giving it a go Tuesday!!
Post #486270 Mon Feb 01 2016 1:30pm
Chilly07
Australia
Well....started this morning. Followed Disco-Mickey advice. Definitely take wishbone off...so easier.
Would of finished easily in a day but got called to help new neighbours fix a water leak from their bathroom.
Just got to finish refitting the wishbone, links and a bleed to do.
Thank you Disco -Mickey for your advice.
Chilly
Post #486383 Tue Feb 02 2016 1:24pm
RobP
Just about to do this myself and am ordering all the parts.
Where are the bleed nipples? Haven't looked yet are the on the bar actuator itself? TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #495184 Thu May 05 2016 1:40pm
Maxarn58
Sweden 2006 Range Rover Sport TDV6 HST Java Black
would of what?? Question Confused
Uffe As a rule, I always resist temptations,
unless they are irresistible.
My Ride: 2006 RRS HSE TVD6 Java Black/Cherry Woods with HST factoryfitted pack.
Post #495303 Fri May 06 2016 9:43pm
RobP
Sorry fat fingers and small phone keyboard don't mix!
Anyone confirm the location for the bleed nipples for the front dynamic response anti roll bar please TDV8 now with extra grin factor thanks to Alive Tunning: Gone but not forgotten
Post #495304 Fri May 06 2016 10:09pm
The bleed nipples are on the ends of the big drum part of the anti roll bar. One at each end and they at the top between the bolts that holds the thing together. Not sure how you bleed it without LR's magic box though. 2012 SDV6 - it's missing a couple of cylinders
Post #495319 Sat May 07 2016 10:53am
