Home > Technical > Vehicle rolls in Park. |
foxtrotzulu Member Since: 04 Sep 2015 Location: West Berkshire Posts: 152 |
While stopping for a second the other day I noticed that if the transmission is set to 'Park' then it fails to stop the car rolling if on a very slight incline. The movement is accompanied by a sort of clicking noise that sounds, and probably is, some sort of pawl failing to engage in a cog. In all other respects the vehicle seems to work OK. (Apart from occasionally losing power on roundabouts - but I'm 99.9% sure this is a separate issue)
Tue May 17 2016 7:42am |
I think your diagnosed exactly the issue. not common at all, but can happen on autos. Either use the handbrake and live with it, or it may need taking apart.
Tue May 17 2016 7:47am |
That's very helpful. Thanks! |
Tue May 17 2016 8:42am |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4946 |
There is a TSB for this.
Tue May 17 2016 11:04am |
Thanks - Is there a link to the TSB or some way of viewing it? |
Tue May 17 2016 1:48pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
There is this one but refers to very early cars.
Tue May 17 2016 4:56pm |
Hmmm - Sounds like the TSB may not be applicable. Bizarrely, the problem seems to have corrected itself the last time I tested it. I'll see how it goes before I get the garage to dismantle the entire gearbox! |
Wed May 18 2016 10:32am |
