Home > Technical > Vehicle rolls in Park.
foxtrotzulu
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Buckingham Blue
While stopping for a second the other day I noticed that if the transmission is set to 'Park' then it fails to stop the car rolling if on a very slight incline. The movement is accompanied by a sort of clicking noise that sounds, and probably is, some sort of pawl failing to engage in a cog. In all other respects the vehicle seems to work OK. (Apart from occasionally losing power on roundabouts - but I'm 99.9% sure this is a separate issue)
Any thoughts?
(I might post this on the Disco forum too as I assume they are also liable to the same issue)
Post #496247 Tue May 17 2016 8:42am
Bodsy
Site Sponsor
I think your diagnosed exactly the issue. Thumbs Up not common at all, but can happen on autos. Either use the handbrake and live with it, or it may need taking apart.
Of course also check that the gear linkage is freely moving and greased up on the side of the gearbox. Could be that it's just not able to go fully home due to corrosion. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #496248 Tue May 17 2016 8:47am
foxtrotzulu
That's very helpful. Thanks!
Post #496254 Tue May 17 2016 9:42am
There is a TSB for this.
A problem with the ZF gearbox manufacturing.
Post #496274 Tue May 17 2016 12:04pm
foxtrotzulu
Thanks - Is there a link to the TSB or some way of viewing it?
Post #496295 Tue May 17 2016 2:48pm
Publication No. A023
Having read it, it only effects 2005 and 2006 cars.
Vin (sport) LS 916973 to LS 924895
parking pawl guide plate to be replaced
If you want a copy, PM me your email address
Post #496322 Tue May 17 2016 5:42pm
There is this one but refers to very early cars.
http://www.theaa.com/allaboutcars/recalls/...;makeId=C3
Post #496324 Tue May 17 2016 5:56pm
foxtrotzulu
Hmmm - Sounds like the TSB may not be applicable. Bizarrely, the problem seems to have corrected itself the last time I tested it. I'll see how it goes before I get the garage to dismantle the entire gearbox!
Post #496405 Wed May 18 2016 11:32am
