Home > General > Lots of squeaking |
Camelrock Member Since: 31 Aug 2013 Location: North Yorkshire Posts: 1003 |
Been through any road works ? Stone trapped behind the disc try driving in reverse see if it falls out. 2008 G4 RRSport TDV8 current
Fri May 13 2016 8:03pm |
Cotty Member Since: 16 Apr 2016 Location: Wiltshire Posts: 13 |
A stone did enter my thoughts, and done as you suggested.
Fri May 13 2016 8:10pm |
Might be a dry joint, see if you can identify which corner. 2008 G4 RRSport TDV8 current
Fri May 13 2016 8:13pm |
I'll get under it tomorrow, and see what's going on.
Fri May 13 2016 8:17pm |
Nothing seems loose, or about to fall off!
Sun May 15 2016 6:44pm |
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 |
Mine was making a lot of squeaking when my lower arms were worn out. Front bush and ball joint were ok but the rear hydro-bushes on both arms were completely cactus. Get a pry-bar on the rear bush and test the movement. MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
Thu May 19 2016 3:08am |
Had it looked at today.
Thu May 19 2016 7:27pm |
