Home > General > Lots of squeaking
Cotty
Lots of squeaking
09/10 RRS
No previous sounds, squeaks or anything.
Been out in the car tonight, and it's making a lot of noise underneath.
Squeaking, rattling, and a kind of rubbing noise.
If I drive on a straight, smooth road, it's ok.
Can anyone shed any light please?
Post #495894 Fri May 13 2016 7:42pm
Camelrock
Been through any road works ? Stone trapped behind the disc try driving in reverse see if it falls out. 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #495897 Fri May 13 2016 8:03pm
Cotty
A stone did enter my thoughts, and done as you suggested.
It is however, a lot more noise than just a stone.
I've just noticed, it's squeaking when I lift and lower the suspension.
Post #495898 Fri May 13 2016 8:10pm
Camelrock
Might be a dry joint, see if you can identify which corner. 2008 G4 RRSport TDV8 current
1994 Dakar current
Post #495900 Fri May 13 2016 8:13pm
Cotty
I'll get under it tomorrow, and see what's going on.
Cheers.
Post #495901 Fri May 13 2016 8:17pm
Cotty
Nothing seems loose, or about to fall off!
I recon it's a dry joint or 2.
Post #496112 Sun May 15 2016 6:44pm
RichG
Australia 2008 Range Rover Sport TDV6 SE Chawton White
Mine was making a lot of squeaking when my lower arms were worn out. Front bush and ball joint were ok but the rear hydro-bushes on both arms were completely cactus. Get a pry-bar on the rear bush and test the movement. MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
2001 Audi A4 1.8T quattro 5mt sport, 340k km
1990 Nissan Pintara TRX, lots of mods, 438k km
Post #496482 Thu May 19 2016 3:08am
Cotty
Had it looked at today.
ARB bushes making all the noise. No play in them, so the garage lubricated them, and the noise seems to have gone for now.
Would non OEM bushes cause this?
Post #496544 Thu May 19 2016 7:27pm
