Home > Faults & Fixes > Injector leak
Lee69
England 2008 Range Rover Sport TDV8 HST Bonatti Grey
Injector leak
Hi guys could anyone help me? I have a rrs tdv8 which is leaking fuel from the furthest away injector as if your standing in front of the car on the right side. It is leaking and dripping onto the engine causing it to smoke. Is it common or am I in trouble. Can I fix it my self or not. I'm pretty handy at doing stuff too.
When I start the car I can see it drip every second.
I would be great full any help.
Thanks
Lee
Post #495857 Fri May 13 2016 1:10pm
Bodsy
Site Sponsor
Is it the injector spill/leak off pipe? The seals fail causing leaks.
I had to do this on one of mine (although changes all the seals on that side whilst there)
Cheap, bit fiddly but do able. Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #495858 Fri May 13 2016 1:18pm
Lee69
I haven't got up close yet as I will have to take out battery and bits and stuff to see.
Can I buy seals if it is them that's leaking. Is it s hard job.thanks lee
Post #495859 Fri May 13 2016 1:21pm
Bodsy
Site Sponsor
 Bodsys Brake Bible
See it HERE
Post #495860 Fri May 13 2016 1:25pm
Lee69
Thanks mate
Post #495861 Fri May 13 2016 1:34pm
Lee69
Just one thing .! On the picture where the blue gloves are holding a connector with a split o ring on it , is that the injector itself or is that another part to it.
Thanks
Lee
Post #495863 Fri May 13 2016 1:55pm
Lee69
[quote="Bodsy"]
[/Just one thing .! On the picture where the blue gloves are holding a connector with a split o ring on it , is that the injector itself or is that another part to it.
Thanks
Lee
Post #495866 Fri May 13 2016 2:07pm
Bodsy
Site Sponsor
That's the leak off part connected to the injector. There's a small metal clip that holds it in place on the injector that sometimes comes out.
I don't have a closer pic of it I'm afraid as I didn't take the injector out.
Will see if I can get a diagram of it connected. Thumbs Up Bodsys Brake Bible
See it HERE
Post #495882 Fri May 13 2016 5:58pm
Bodsy
Site Sponsor
7 is the spill pipe connected to each injector. Bodsys Brake Bible
See it HERE
Post #495885 Fri May 13 2016 6:12pm
Bodsy
Site Sponsor
Shows the clip (ignore the knurled bit as that's a blanking tool)
 Bodsys Brake Bible
See it HERE
Post #495886 Fri May 13 2016 6:15pm
Lee69
Hi guys just an update on the leak problem.
After booking it in to land rover and paying £70 they said they couldn't find the leak. So they jet washed the engine and gave me it back. After getting home I opened the bonnet took off the battery and there it was dripping from the 4th injector. After closely examining it it turned out to be the return pipe o-ring which I guy had suggested to me so thanks again.
The only problem I have is after removing the plastic end with the o-ring on I lost the retaining clip so now I have no o-ring or retainer so my question is, can I buy the bits I need and where would I get them from.
Thanks for helping guys.
Lee
Post #496238 Tue May 17 2016 4:55am
Bodsy
Site Sponsor
Clip only available as an expensive injector fitting kit from LR or available for £2.93 here....
http://www.advancedfactors.co.uk/411-1170s...7084-p.asp
O ring is part number LR019118 Bodsys Brake Bible
See it HERE
Post #496246 Tue May 17 2016 7:39am
Lee69
Thanks for the help
Lee
Post #496250 Tue May 17 2016 8:10am
Lee69
Having trouble trying to obtain the o-rings it says nothing matches your search item number.
Post #496253 Tue May 17 2016 8:41am
I would just like to say a BIG thank you to Bodsy for your continued support and contribution to this site. Going out of your way to help this guy. It's people like you with your knowledge and experience, that makes this site what it is today. Fantastic. Bow down Thumbs Up
Post #496257 Tue May 17 2016 8:54am
