Home > General > Fitting a new DRM module on TDV8 |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4999 |
I could be wrong here but I thought it was on the passengers side behind the kick panel by the lower glove box.
Fri May 06 2016 9:21pm |
Andrew Member Since: 16 Jun 2005 Location: Cheltenham Posts: 248 |
How do you propose programming it to talk to the car?
Fri May 06 2016 9:22pm |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9001 |
The module is on the driver's A pillar behind the instrument panel. Access it through the foot well by removing the two panels. One pulls off, the other has a couple of screws and a clip from memory. Move the seat fully rearwards to help access. You can see the module by getting your head down in the pedals. Note: the air suspension module lives in the same location. The air suspension module has 4 connectors, the DRM only 2 connectors.
Sat May 07 2016 10:44am |
harryp Member Since: 21 Jan 2014 Location: yorkshire Posts: 8 |
Many thanks RRSTDV8. Sorry to trouble you further, but how easy is it to do the setting once installed? Do I need any special equipment? |
Sat May 07 2016 2:52pm |
Not sure whether something like an IID Tool would set it up or whether you need a Land Rover box to do it. 2012 SDV6 - it's missing a couple of cylinders
Sat May 07 2016 4:54pm |
