Home > Faults & Fixes > central locking won't work!!
dkegm
2011 Range Rover Sport SDV6 HSE Santorini Black
central locking won't work, press lock/unlock button on remote boot locks/unlocks but not doors, press lock/unlock button on door card nothing happens? nothing showing up on a scan?
Post #495218 Thu May 05 2016 9:45pm
Paddi
If you fill in your profile so we know which model you have that would help.
Which tool are you using to scan the fault codes - Land Rover specific or just a generic? 2008 MY Java Black TDV8 HSE
Post #495253 Fri May 06 2016 11:52am
Russben
Does the alarm double 'beep' quietly when you try to lock it? If so it could be the bonnet sensor that needs cleaning/setting/replacing. The car thinks something is open so won't allow the car to lock.
Worth a look as it's easy to sort. I'm in the shed, I'll be back in the real world in a minute.
Post #495264 Fri May 06 2016 2:04pm
dkegm
yes alarm double bleeps, where abouts is the bonnet sensor?
scanner is delphi 150s? profile is filled in.
Also parking sensor won't work, the alarm beeps when put in reverser but sensors don't pick anything up?
Post #495289 Fri May 06 2016 8:10pm
PEACHY
I believe Paddi means your Range Rover Sport profile - which is part of your forum profile Thumbs Up this creates the little coloured RRS icon under your username.
This helps other members when answering questions - different Model Years & model variations use different systems / components. 16MY Estoril Blue SVR.............
Post #495294 Fri May 06 2016 9:43pm
