![]() | Home > Technical > Vibration while driving and metallic sound |
An extreme possibility I had on another car, was the Cats had destroyed themselves |
Socast Member Since: 25 Sep 2014 Location: Somerset Posts: 594 ![]() ![]() ![]() |
If it's coming from the centre of the car I would say it's the carrier bearing on the prop shaft.
Rear propshaft is less than half that cost!
I did a quick Google and was getting prices around £600, which I thought was pretty high, but as I said its been awhile since I changed mine so couldn't remember.
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5042 ![]() ![]() ![]() |
http://www.island-4x4.co.uk/propshaft-rear...-7937.html
Stecla Member Since: 20 Jun 2015 Location: Newbury Posts: 157 ![]() ![]() ![]() |
Thanks guys. The car was recovered from home today and is at the garage. I await a call on what it is and when they can do it (and also whether the warranty will cough up). Their first thought based on symptoms is prop shaft (or bearings) so let's see.
Didn't intend to be so brusque ![]() 2008 TDV8 - it was a labour of love and is much missed |
Sorted. Rear prop shaft assembley replaced under warranty 👍🏼 apparently epb had played up too and scored my brake discs so they needed to be replaced to but not covered. At least is done. 2010 TDV8 |
I would ask to see your old brake disks, I can't see why they would strip your rear hub's when they're replacing the propshaft.. sounds like a quickfit money spinner to me. |
Gornal Hills Member Since: 10 Nov 2014 Location: Dudley Posts: 380 ![]() ![]() ![]() |
Hi, please correct me if i'm wrong but i thought the EPB worked with shoes and rear hubs, nothing to do with the rear discs ?? |
The EPB brake shoes work in a brake drum in effect machined inside the Rear Disc so how on earth you would see that was damaged with out stripping it out I don't know. I suppose it could have been binding and overheated/damaged the rear discs or something like that but would have thought EPB shoes etc. would have needed replacing as well, it sounds slightly suspect.
Hi Gornal, The EBP does work with a drum and shoes, but as with most modern cars the rear drum is now integrated into the brake disk. Take a look at this video: |
Hi Socast, thanks for the vid, certainly makes more sense now. I always wondered how much you backed off the EPB and now i know |
Apparently one of the clips had perished and had caused the shoes to score the discs (or something like that). Makes sense, as had been making a squeak for some time (now not). To be clear, I asked them to investigate this at the same time.
