Home > Maintenance & Modifications > Interior LEDs |
LeeRRS Member Since: 19 Nov 2015 Location: UK Posts: 43 |
there are kits available on flebay with all the replacement bulbs you need. I wouldn't change them they are far too bright. 2012 Range Rover Sport Autobiography 3.0 SDV6
Tue Apr 26 2016 5:19pm |
LJRH Member Since: 22 Apr 2016 Location: Hertfordshire Posts: 209 |
There are indeed however they're over priced, considerably, and also don't say which type of bulb they are hence me asking the question. |
Tue Apr 26 2016 5:26pm |
Well the kit i purchased just said "all interior bulbs set" if you want to replace just one or two bulbs then i think it's best you remove the existing ones, and if the + and - are in the same place as the replacement. I hope that makes sense. When i installed mine, i had to adjust (push back) the connection terminals to make the LED bulb fit. 2012 Range Rover Sport Autobiography 3.0 SDV6
Tue Apr 26 2016 5:38pm |
It does, but how many are 501s, how many are festoon etc |
Tue Apr 26 2016 5:40pm |
you got me there mate, i'm not sure. I thinks your best bet is to remove them and order LED replacements accordingly. 2012 Range Rover Sport Autobiography 3.0 SDV6
Tue Apr 26 2016 5:46pm |
HemoRRS Member Since: 31 Mar 2016 Location: Wolverhampton Posts: 254 |
501 are
Tue Apr 26 2016 6:35pm |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4971 |
Glove Box 501 x1
Tue Apr 26 2016 8:22pm |
Thank you both that's perfect! |
Tue Apr 26 2016 10:22pm |
What are the ones on the underside of the wing mirrors by the way
Tue Apr 26 2016 10:29pm |
Yup |
Wed Apr 27 2016 8:57am |
Thanks |
Wed Apr 27 2016 10:57am |
deano_123 Member Since: 13 Aug 2015 Location: Newcastle Posts: 108 |
Are these straightforward to fit? I hadnt realized there was lights in there |
Wed Apr 27 2016 7:25pm |
TheWojtek Member Since: 08 May 2015 Location: PoznaĆ, Poland Posts: 737 |
I believe they were factory fitted on HSE, HSE Luxury and SC only. Should be pretty easy to retrofit, though, as the generic mirror housing has a space provided for the lamps. Regards etc.,
Wed Apr 27 2016 8:32pm |
I have an HSE so I assume they are, I've not bothered to look and rarely drive the car after dark to have realised. |
Wed Apr 27 2016 8:57pm |
