Home > Technical > Brake lights not working ?
davidsherry33l
United Kingdom 2007 Range Rover Sport TDV6 HSE Santorini Black
Hi ,
My brake lights seem to have stopped working , the light at the top of my tailgate still works correctly and I connected a trailer to my car and the trailer lights worked correctly , and when I put my side lights on they also light up , so I cannot understand why they don't light up fully when I press the brake pedal ??
Any advice would be greatly appreciated
Post #494280 Sat Apr 23 2016 4:52pm
Have you checked the bulbs ?
Post #494281 Sat Apr 23 2016 4:53pm
davidsherry33l
I have looked at the bulbs and they look fine , they are 2 elements inside which look ok , and like j said the side light part is working , I didn't want to drive to halfords and buy new bulbs when there is probably nothing wrong with the ones that are in , both lights going off at the same time would suggest a fuse maybe ??
Post #494284 Sat Apr 23 2016 4:57pm
I wouldn't buy bulbs from halfords anyway.
Do you get a dashboard message to tell you the bulbs are out on yours ?
Post #494286 Sat Apr 23 2016 5:02pm
Lost for Words
The high level light is wired on the same circuit as the others, so not a fuse or switch issue. Any other issue would have to affect either the tail filaments due to the common ground or the high level light and fuse if a dead short, and would be very unlikely to affect both sides at the same time, so we are back to the bulbs...
Never a bad idea to change them over regardless since they can cause such havoc. Check your alternator, because they could have been blown by a voltage spike.
Thumbs Up Visiting from DISCO3.CO.UK
Post #494287 Sat Apr 23 2016 5:03pm
davidsherry33l
80 pence at the petrol station problem fixed Smile I'll have to keep an eye on them in future !
Thank you for your help and advice ! It's very much appreciated !!
Post #494293 Sat Apr 23 2016 6:04pm
