Home > Technical > Brake lights not working ? |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 4950 |
Have you checked the bulbs ? |
Sat Apr 23 2016 4:53pm |
davidsherry33l Member Since: 12 Dec 2015 Location: hartlepool Posts: 23 |
I have looked at the bulbs and they look fine , they are 2 elements inside which look ok , and like j said the side light part is working , I didn't want to drive to halfords and buy new bulbs when there is probably nothing wrong with the ones that are in , both lights going off at the same time would suggest a fuse maybe ?? |
Sat Apr 23 2016 4:57pm |
I wouldn't buy bulbs from halfords anyway.
Sat Apr 23 2016 5:02pm |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
The high level light is wired on the same circuit as the others, so not a fuse or switch issue. Any other issue would have to affect either the tail filaments due to the common ground or the high level light and fuse if a dead short, and would be very unlikely to affect both sides at the same time, so we are back to the bulbs...
Sat Apr 23 2016 5:03pm |
Sat Apr 23 2016 6:04pm |
