Home > Technical > Auto Gearbox Faults |
shakeapaw Member Since: 17 Dec 2011 Location: in a mud hut in wigan Posts: 948 |
It was fixed in May 2014, and has been good ever since, just over 10k miles on it. It was fixed by a AUtogearbox company my indie recomended, in MAnchester 07,TDV8,Black, Black Heated leather all round, Rear Entertainment with Headpones & Remote, TV, DVD, Pure Dab Digital Radio, Sidesteps, Adaptive Headlights, sunroof, now working fuel burning heater ))) |
Tue Apr 19 2016 10:21am |
I was quoted £2700 for a recon gearbox and torque converter from Bristol Autos. That price included all labour. |
Tue Apr 19 2016 10:32am |
Farax100 Member Since: 18 Apr 2016 Location: London Posts: 12 |
although I had the 'transmission fault' a few times and the limited gears message whiles on the 20" and climbing up a hill in Greenwich, I changed the wheels to 22" about a 8 months ago, do you think this made the gearbox issue worse?, I know bigger wheels can effect the gear ratios..
Tue Apr 19 2016 10:58am |
Lost for Words Member Since: 15 Jan 2015 Location: Warminster, Wiltshire Posts: 1477 |
The wheels are unlikely to have made a significant difference. Most likely the stator bushing has worn, and the consequential contamination was masking the problem - when the oil is then changed, it is thinner and thus the issues appear. This is why it's important to get the ATF changed early and often. Visiting from DISCO3.CO.UK
Tue Apr 19 2016 11:07am |
Update on the gearbox situation finally...
Tue May 31 2016 9:55pm |
RichG Member Since: 23 Nov 2012 Location: Adelaide AU Posts: 29 |
That looks like the usual outcome of gear ratio codes. If the oil appears ok (yours looks terrible!) and is at correct level, you're almost certainly up for new clutches at a minimum, but I'd also test the valve body to make sure it's holding vacuum at the solenoids. MY08 RRS TDV6, Chawton/Black, sunroof, hk, 268k km
Wed Jun 01 2016 12:39am |
gogsy1956 Member Since: 15 Jun 2013 Location: Tyne and Wear Posts: 948 |
That's a scary amount of clutches etc,,, I hope they didn't leave anything out 2010 RRS, TDV8
Wed Jun 01 2016 8:41am |
It's not a DIY job that's for sure, I just drove it up the M4 for 45 minutes at 70-80, no chimes or error messages at all...
Wed Jun 01 2016 10:10am |
Quality works Member Since: 30 May 2016 Location: South east Posts: 10 |
Glad to hear your happy again. Nothing worse than your lady laid up,
Wed Jun 01 2016 10:24am |
SH0X Member Since: 25 Jan 2016 Location: London Posts: 82 |
Farax100
Thu Aug 04 2016 2:32pm |
