Home > General > Dull headlight lens
Yetiman
2006 Range Rover Sport TDV6 HSE Stornoway Grey
Dull headlight lens
My headlight lenses are a bit dull. Was thinking about trying to polish them up a bit but not sure the best way to go about it. Any Ideas ?
Jez
Post #493772 Mon Apr 18 2016 1:11pm
Camelrock
T-cut and abit of elbow grease Thumbs Up 2008 G4 RRSport TDV8 current
2009 TDCi 90 current
1994 Dakar current
Post #493776 Mon Apr 18 2016 1:47pm
HemoRRS
Wet & dry and soapy water, did mine finished up with 2000 grit. Think I started at 800.
Like new now.
Post #493779 Mon Apr 18 2016 1:50pm
Socast
The lenses are plastic with a lacquer coat.
If you t-cut them they will look great for a few months and then the plastic will start to get stained and cloud as it's no longer protected.
Do it properly at your local body shop. I had mine flattened and re-lacquered for £45.
Post #493794 Mon Apr 18 2016 2:42pm
Yetiman
Didn't know about the laquer, maybe get the pro's to sort it then.
Post #493861 Mon Apr 18 2016 8:39pm
Bladeboy
England 2005 Range Rover Sport TDV6 HSE Siberian Silver
I've heard toothpaste suggested before- I guess it's quite abrasive too though
Post #494046 Wed Apr 20 2016 9:23pm
Could try Meguiars Plastx plastic cleaner and polish.
Post #494054 Wed Apr 20 2016 10:59pm
CRACKA
Australia 2006 Range Rover Sport Supercharged Bonatti Grey
Yes there are a couple of Lens cleaners out there .They work very well and the better ones have a final protective coating to apply when the job is done. 2006 4.2 S/C with Tow Pack, Side Steps, DRL's, 19" & 20" wheels, additional 110 ltr Fuel Tank Roof Rack and performance mods.
1952 Rover 75 (Cyclops) First Car !!! Fond memories -was restored-good for 93mph.
Post #494062 Thu Apr 21 2016 6:17am
adameverett
Funny, I was in Halfords just last lunch time picked up this
http://www.halfords.com/motoring/car-clean...dlight-kit
As previous posts suggest lens is plastic and just t-cutting or tooth paste is short term win (weeks), this kit has 2 bottles a cleaning solution (is it a mild cutting compound?) and a final coat spray ( is this just a clear laquer?)
£30 seemed a bit steep, but if it works well really tempted to try it, any one else tried this kit?
I have the Megs NXT polish and really impressed with the quality duration of the product, so as a quality brand tempted to give this one a go.
Post #494066 Thu Apr 21 2016 7:37am
Socast
I tried the Meguiars 1 step, that's when I learned about the lacquer. The two step stuff should be better as I'm guessing the second step is a lacquer.
Post #494073 Thu Apr 21 2016 9:33am
Just read the instructions on the rear of the PlastX Bottle and it says not to use on coated plastics, so if there is a lacquer coating on the lens I guess that would mean that as well.
So probably not advisable to use the PlastX cleaner.
Post #494075 Thu Apr 21 2016 9:47am
HemoRRS
Any headlight that's speckled/cloudy means the the top coat has/is coming off.
Any headlight restoring product will only make this worst as they are all abrasive.
Plastic headlight lenses are polycarbonate, which UV rays will deteriorate making them cloudy the top coat is essentially just a UV protector to delay this.
If you want to do it properly the best way is with a selection of wet and dry and then a UV protecting top coat. If done properly this will last for 5 years plus before needing doing again.
If done without a top coat they will need doing again in 12-24 months.
Post #494076 Thu Apr 21 2016 10:19am
Ian.H
United Kingdom 2008 Range Rover Sport TDV8 HST Java Black
Polish it either with a machine or toothpaste, then apply a layer of wax over it. Wax the lights when you wash the car again... job's a good'en Smile
Cheers..
Ian
Post #494080 Thu Apr 21 2016 10:53am
