Home > In Car Electronics > Bluetooth mic not working.
HemoRRS
The CD changer was jammed on my recently purchased RRSport, the dealer replaced this for me and picked the car back up yesterday, unfortunately they've replaced it with another fault and now the BT mic is not working.
I'm presuming a loose wire is the culprit, anyone know the wire colour at the back of the HU? Or could it of even come loose by the mic itself with pulling and tugging? I'm presuming this is by the interior light and an easier job to rule out?
Thanks
Post #493626 Sat Apr 16 2016 11:32am
there is a 2nd connector which is used for the mic and aux input from the rear console.
So if the aux input isn't working either, that connector may be unplugged
Post #493630 Sat Apr 16 2016 12:35pm
HemoRRS
Thanks for that, just tried the aux and that's all working.
Post #493634 Sat Apr 16 2016 12:53pm
Bodsy
Site Sponsor
You usually have to run another wire from the back of the head unit to the MIC. It's quite straight forward if your vaguely competent with a soldering iron Thumbs Up
If you're not, I can fix that for you. Thumbs Up Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #493666 Sun Apr 17 2016 7:56am
HemoRRS
Thanks Bodsy,
I'm sure I can manage that, are you anywhere near the Bridgnorth side of Shropshire?
I am considering a remap and egr delete for my TDV8.
Post #493671 Sun Apr 17 2016 9:20am
Bodsy
Site Sponsor
Indeed, 8 mins from Bridgnorth. Thumbs Up there's quite a few RRS in Bridgnorth I've remapped already. Bodsys Brake Bible
See it HERE
Post #493733 Sun Apr 17 2016 8:30pm
