Home > General > Pitted sidesteps, what to do?
Newstuart
Very happy with my new range rover and just doing a few jobs to get it right. The sidestepps appear rather pitted and I have been unable to get them clean. What does everyone else do?
Im considering powdercoating or wrapping them but would rather restore them and stay OEM
Post #493554 Fri Apr 15 2016 4:42pm
Do you mean the side strips on them? Or do you have the bars?
If you have side steps, not bars, to clean, I'd use a 0000 gauge wore wool and some metal cleaner (I used the britemax twins, quick Google will find them).
Then get something on them to protect them, either wax or sealant.
Some people have painted/powder coated. Just depends on the looks you're after. Not sure wrapping would stand the test of much time as they are in a pretty vulnerable location. ON THE WAY: BMW F21 M140i
Post #493556 Fri Apr 15 2016 5:28pm
Newstuart
Hi, thanks for the response. These are the type I have, are they the same as yours ?
Post #493562 Fri Apr 15 2016 5:52pm
Yes, they were the ones.
Definitely order some 0000 gauge wore wool and a decent metal polish, even something like autosol available from Halfords.
Bit of elbow grease and they should come up better Thumbs Up ON THE WAY: BMW F21 M140i
Post #493572 Fri Apr 15 2016 7:27pm
Newstuart
Great ill do just that, thanks for the advice, much appreciated
Post #493574 Fri Apr 15 2016 7:32pm
big pimp
And be careful with what you use to wash with, or what the polish / Romanian car washes use.
Those trims are Aluminium and anything caustic (most TFR's etc will be) will pit them MY10 HSE 3.0 TDV6 : Santorini Black : Ebony Interior w/Anigre wood : Privacy Glass (total) : Sunroof : Sidesteps : Hybrid TV : Detachable Tow Kit : Spare Wheel Cover : 22" Dished Supersports
Post #493618 Sat Apr 16 2016 9:23am
Gornal Hills
United Kingdom 2007 Range Rover Sport TDV6 HSE Cairns Blue
Hi, the correct thing to clean them with in an Anodised rubber which is what we use on Aluminium windows and shop fronts to remove stains. It is oil and other liquids that end up getting on them due to there location, if i were you i would keep it simple and wash them, clean with wire wool, mask and spray silver Thumbs Up 2007, HSE, Cairnes Blue, Factory tints, Love it !!!
Post #493619 Sat Apr 16 2016 9:49am
ChrisL
United Kingdom 2010 Range Rover Sport 3.0 TDV6 HSE Adriatic Blue
Hi
I have a 2010 Range Rover Sport and need to get some rust marks off the silver part of the side steps can someone confirm they ar aluminium please?
I bought T Cut metal polish and it says do not use on chrome finished plastics but is alright for aluminium.
Post #581523 Wed May 29 2019 2:46pm
knwatkins
Aluminium does not rust Wink Kev
Post #581535 Wed May 29 2019 5:50pm
ChrisL
It might not be rust but it is discoloured, thought it was mud till we got it cleaned.
That is why I am checking what the silver part of side steps is.
Chris
Post #581539 Wed May 29 2019 6:07pm
knwatkins
I always thought it was an aluminium alloy. I used some rubbing compound on mine and it didn't get them perfect, but it certainly improved them...
https://www.halfords.com/motoring/paints-b...g-compound Kev
Post #581544 Wed May 29 2019 6:16pm
mrluke
magic sponge and autosol ( done halfway below)
I also used some abrasive cleaning pads on a drill and it took off the anodizing Sad the pitting and scratches on mine was just too bad .. so im replacing them for black versions.
Post #581576 Thu May 30 2019 7:48am
Brit Plumber
Winter road salt! It tarnished mine before they were 6 months old. I’ve micromeshed mine but I want to have them painted gloss black along with my D pillar trims. 2019 5.0 SC SVA (Current)
23 plate Focus ST (Current)
Post #581584 Thu May 30 2019 8:25am
