![]() | Home > Technical > "Low battery warning - start car" |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 5046 ![]() ![]() ![]() |
Yes, easy to use. If you have twin electrics or the 13 pin type then you can charge via an adaptor lead from the shop on here. Or simply connect to battery and earth point....lots of posts on here about it |
Andy K Member Since: 18 Sep 2015 Location: GL Posts: 5020 ![]() ![]() ![]() |
A CTEK 5.0 should be plenty.
denny111 Member Since: 07 Dec 2014 Location: Kent Posts: 98 ![]() ![]() |
hi mate
I ordered a M8 comfort connector off ebay £4.95. (they are a bit longer)
ok thanks for the info |
Frax Member Since: 07 May 2015 Location: Aberdeenshire Posts: 241 ![]() ![]() ![]() |
I get the same warning if I park up and put the TVs on, this warning comes in at about 2min later.
LR advice: never play with the toys with engine off |
So why fit them if not suitable for use if engine not running. Crazy. John
muddywheels Milk Float Man Member Since: 30 Jun 2010 Location: East Riding of Yorkshire Posts: 5637 ![]() ![]() |
Totally agree Johnski |
I get warnings when TV or DVD playing, and strangely the Radio turns itself off after 15 minutes if put on to listen to. |
