Home > In Car Electronics > Fitting aftermarket phone kit - bluetooth
I'm intending fitting an aftermarket phone kit.
I think I have located the mute pin on the headunit (on the secondary audio input connector, Pin 10?) however does anyone know if there are any audio input pins for when mute is active, to save me fitting another speaker.
I have the external amplified system.
Thanks
Post #492199 Wed Mar 30 2016 12:17pm
Johnski
I Can't help you as the steering wheel phone switches and Bluetooth etc were standard fit, but if you go to the LR site you should be able to find parts and wiring diagram on there which may assist you. Unless someone has already done an after Fit? John
Post #492209 Wed Mar 30 2016 1:21pm
Bodsy
Site Sponsor
What kit are you fitting? You can usually get a plug in wiring adapter to most popular units like parrot etc n Bodsys Brake Bible
Software Updates Contact me
See it HERE
Post #492219 Wed Mar 30 2016 4:05pm
Nokia ck-7w
The problem is the RRS has an external amplifier therefore the standard mute kits arn't a lot of use.
Post #492221 Wed Mar 30 2016 4:58pm
Bodsy
Site Sponsor
Blimey! I've got one of those I removed from my 2003 Merc!
ive not got the wiring diagram from the wiring kits I've used, but it is possible. If I get a chanc later,mill have another look at the pinouts.
If you get bored, I think Bobby or someone put the audio pinouts posted up on here as well. Thumbs Up Bodsys Brake Bible
See it HERE
Post #492224 Wed Mar 30 2016 5:05pm
I did a search but couldn't find the pin outs
Post #492264 Wed Mar 30 2016 10:26pm
TheWojtek
Whoa, I'm interested in this CK7-W kit schematics as well - as long, as it works with stock wheel controls. It's dirt cheap and still some old-school quality stuff.
Found this: http://www.carcommunications.co.uk/car-acc...-bury-lead Regards etc.,
Wojtek
WAS: 2006 RRS Supercharged
IS: 2010 RRS TDV8 HSE
Post #492319 Thu Mar 31 2016 3:30pm
The CK-7W won't work with stock wheel controls as standard.
I was considering removing the steering wheel button illumination function, and using that wire so a button could control the nokia system.
I doubt the kit you link to would work.
I happened to have a jag mute kit to hand and plugged it in. All it did was provide power for the phone kit.
Post #492334 Thu Mar 31 2016 6:15pm
TheWojtek
Damn :/ Regards etc.,
Wojtek
Post #492409 Fri Apr 01 2016 12:04pm
Well to answer my own question.
On the smaller connector.
Pin
10 Mute
3 Audio In +
5 Audio In -
Did this today. Bolted it and wired to the head unit. Laughing
Some of you may think its a bodge.
I don't use the phone much in the car so it will be sufficient for me. (with parts I had)
[URL=]
[/URL]
Upgraded the landrover unit to include bluetooth
[URL=]
[/URL]
Post #493210 Sat Apr 09 2016 9:29pm
TheWojtek
Thumbs Up great hack.
How do you answer the phone? Using the actual handset? Regards etc.,
Wojtek
Post #493219 Sat Apr 09 2016 10:59pm
You answer the phone by pressing the phone button on the head unit. Razz
Although implementing this bit isn't really a diy task.
Post #493223 Sun Apr 10 2016 6:11am
