Home > Technical > Noise and harshness from transmission |
ash768w Member Since: 26 Mar 2016 Location: southampton Posts: 6 |
Hi all.
Mon Mar 28 2016 8:54pm |
Thanks. i work in Bishops Waltham so that would be ideal.
Tue Mar 29 2016 7:01am |
RRSTDV8 Member Since: 12 Aug 2011 Location: Northamptonshire Posts: 9003 |
Sounds like it might be the torque converter clutch. As it wears out it starts to judder - sometimes referred to as the "cattle grid" effect because it feels/sounds like driving over one. It's a known issue with gearbox and affects all marques that use the ZF 'box.
Tue Mar 29 2016 8:08am |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
I'd chuck it back at them to fix it udner warranty.
Tue Mar 29 2016 11:06am |
West 4x4 have took a quick look but they arent 100% on the cause, they got it to do it straight away and said transmission but cant say what part without more extensive diagnosis. i have called the dealer and they have told me they want it taken to their local garage 50 miles away so i have told them to get it recoverd if that is the case as im not risking driving it that far unless i have it in writing that they accept all responsibilty. i'm still waiting for their responce....
Tue Mar 29 2016 12:23pm |
If you've only just bought it then what's the issue!?
Tue Mar 29 2016 1:08pm |
Wot he said ^^^ re: warranty rights etc Visitor from fullfatrr.com
Tue Mar 29 2016 4:32pm |
So I rang the dealer and after he finished with his attitude he eventually said take it to the garage they use in Newbury so notes that where she is now.
Tue Mar 29 2016 6:49pm |
I think the purchaser should return this vehicle to the reseller and ask for his money back in full, as under the sale of goods act, not a good start and you don't know what you have got with this vehicle, future problems out of warranty? Best of luck, but plenty of decent cars out there. John RRS MY12 SDV6 HSE. Sumatra Black/Ebony & Walnut + Dynamic Pack, + Cold Climate Pack + Memory Pack, Digital TV/DVD, Premium Leather, Cornering Lights, Cooler/Fridge Box, & most Options. |
Tue Mar 29 2016 7:12pm |
erickwan Member Since: 27 Mar 2016 Location: P Jaya Posts: 138 |
This is a common problem with the ZF6HP26 when used on the BMW's as well. It's usually the partial failure or the failure of the seal between the valve body and gearbox resulting in a drop in oil pressure. It's a £17 part and usually fails around 70,000 miles. Getting to it is a bummer as the valve block & mechatronic units needs removing to gain access. Driving the vehicle in this condition risks further major damage to the gearbox components. |
Wed Mar 30 2016 3:46am |
They have had it since tuesday and i have had no update so i called them.
Fri Apr 01 2016 12:43pm |
I personally would reject it now, the garage are obviously giving you the run around and have been since you bought the car.
Fri Apr 01 2016 2:39pm |
Fri Apr 01 2016 2:43pm |
I agree. Reject it and find another Visitor from fullfatrr.com
Sat Apr 02 2016 3:22pm |
