Home > Faults & Fixes > Help multiple faults |
Col Member Since: 02 Sep 2012 Location: Hawkes Bay NZ Posts: 4974 |
This is only a suggestion, but if you have just had new alternator and battery fitted, I think I would check that all connections and battery terminals are tight first.
Wed Mar 23 2016 7:01pm |
virdi0 Member Since: 28 Sep 2012 Location: Dunstable Posts: 4 |
All connections are tight. Green flag did the battery test and ok. Charging and holding a charge. The speedo also stopes working. Can you swop the hight sensors from right to left? Just so I can rule out a faulty sensor. Thanks |
Wed Mar 23 2016 8:05pm |
DrRob Member Since: 23 Feb 2011 Location: Hampshire Posts: 2011 |
Perhaps get Geoff (site sponsor and mechanic) to read the codes for you. Modern cars rely on codes being read to get an idea of the problem Visitor from fullfatrr.com
Wed Mar 23 2016 8:41pm |
Just an update. I had the wheel liners off and wd40 all the plugs. I also had the solanod block apart cos the front dropped over a few days. It's now fixed. All warning lights are out and suspension is working as it should. |
Fri Mar 25 2016 1:12pm |
Fri Mar 25 2016 2:07pm |
